Saurav
- Feb 15, 2001
That's been my big question with DBTs the switcher box. If you take that out of the picture, then you're manually swapping components, and that takes too long to be meaningful.
Here's an analogy - can most people tell the difference between a 50Hz tone and a 100Hz tone? Yes, they can, those are a full octave apart. Can most people tell the difference between a 10,000Hz tone and a 10,050Hz tone? I think that would be much harder to differentiate, as that's probably less than a note apart. Human response to a lot of things is logarithmic - a doubling of volume is perceived as a linear increase in loudness, a doubling of frequency is perceived as a linear increase too - every octave sounds the same 'distance' away from the previous one.
So, I wonder if something like that can be a factor, that the act of adding the switch box in the middle can mask the difference between the components and make it harder to hear - the difference is still there, in the same magnitude, but it's been shifted to another point on a scale. Just speculating...
