Don't want to seem like a total dufus BUT.....
Discussion in 'Home Theater Projects' started by WendyS, Apr 4, 2004.
  1. WendyS
    WendyS Stunt Coordinator
    Mar 11, 2004
    84
    I bought a bunch of these and there are no instructions how to use them.
    [​IMG]
    I searched for an NXG website for help but couldn't find one.
    Inside each connector there is a small plug.
    My guess is to insert the speaker wire, add the plug and screw until it is tight. Yes? No?
    What are the openings in the side for?
    I'm not sure how far back to strip the wires.
  2. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    Yes, insert the wire, add the plug if needed, and screw until it is tight.
    Strip just enough from the end of the speaker wire so that the bare end goes as far as it can go through the connector, and the plastic insulation also goes as far as it can go except the insulation is never squeezed in the screw down. If you stripped too much, cut a little off the bare end until you get it right
    The other opening is used if you want to connect two or more wires into the same jack in the amplifier or speaker system (rare) and you fasten one connector to the end of each wire and then insert the second connector into the first connector etc.
    If the wire is too thin to be caught when you screw things down, you can insert it anywhere that it can be caught tight with metal to metal contact.
    Video hints:
    Actually if you can fasten the wires directly to the amplifier or speaker system with good metal to metal contact, and you don't need to undo and redo the connections frequently even for moving and vacuuming around etc. then you don't need those connectors.
  3. ScottCHI
    ScottCHI Screenwriter
    Feb 21, 2004
    1,292
    piggy-backing those like that is great for bi-wiring
  4. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    The side opening is the best place to insert the wires, actually, the back is where the plugs can piggyback.
    -Vince
  5. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Is this a hole with a side-screw, or does the back-end of the banana plug come off if you un-screw it enough?
    If the back end comes off you do this:
    - Unscrew the back end
    - Shove speaker wire up through the hole
    - Strip about 1/8 inch (very small amount) of insulation
    - "Fan" the copper fibers back. The back-end should have a slanted area for these to lay against
    - Screw the top-part back on which will crush the copper fibers between the 2 parts to give a very strong mechanical and electrical connection.
    IMPORTANT: make sure there are no copper strands of wire sticking out the sides. These can later cause shorts as the wires sag against each other over the years.
    Hope this helps.
  6. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    Those look like Radio Shack? Yes?
  7. ScottCHI
    Feb 21, 2004
    1,292
    no, that hole on those particular banana plugs is strictly for piggy-backing another plug. although the back does screw off, the hole does NOT "go through".
  8. Kevin Deacon
    Kevin Deacon Second Unit
    Dec 18, 2001
    319
    I shoved my wire through the back and soldered it to the inside.
