kuttaS
- Jul 21, 2003
found this cool forum on neoseeker about dolby's new prologic. check it out http://www-3.ibm.com/software/succes...t&Site=default
Dolby Pro Logic IIx is the first and only technology to process any native stereo or 5.1 signal into a 6.1- or 7.1- channel output, creating a seamless, natural surround soundfield that immerses you in the entertainment experience.What about Logic 7 or Rotels XS processing? they can both do 7.1 from 5.1 and L7 can do it from 2 channel as well. And Rotels XS processing runs on top of PLII or DTS NEO to generate the back two channels so this really isn't anything that new.
What about Logic 7 or Rotels XS processing? they can both do 7.1 from 5.1 and L7 can do it from 2 channel as wellIt's all in the phrasing. What I suspect they mean is that DPL IIx is the only one that can do either "6.1" or "7.1". Logic 7 doesn't have a setting for a "6.1" configuration, and I assume Rotel doesn't either.
M.
It's all in the phrasing. What I suspect they mean is that DPL IIx is the only one that can do either "6.1" or "7.1". Logic 7 doesn't have a setting for a "6.1" configuration, and I assume Rotel doesn't either.Actually Rotels XS works great for 6.1 or 7.1
Actually Rotels XS works great for 6.1 or 7.1Someone tell Dolby.
M.
