Dolby Prologic II or Dolby Digital 5.1
Discussion in 'Archived Threads 2001-2004' started by daniel socal, Dec 27, 2002.
  1. daniel socal
    daniel socal Auditioning
    Dec 27, 2002
    2
    Please forgive a newbie question. My old second hand receiver died last week (A Yamaha Pro Logic), and I replaced it with a Denon 1403. I connected my DVD player via a digital coax cable to the receiver and sure enough, the digital indicator on the receiver lights up.
    So, here is my question...
    When I got the old receiver, it was explained to me that Dolby Pro Logic was an "program" sends a percentage of the audio signal to each of the 5 speakers according to a mathmatical formula. Dolby Digital 5.1, on the other hand, send a discrete signal to each speaker according to how the sound is encoded at the source (i.e. send this sound to the left rear, send this sound to the center, etc.)
    My new receiver supports both Dolby Digital 5.1 and the "new" Dolby Pro Logic II. When I play a DVD, the receiver seems to want to use Pro Logic II. Is Pro Logic II better than 5.1? Is it more advanced? Should I use it, or will my movies sound better by setting it to 5.1?
    I've tried reading the manual and searching the forums for hints, but most explainations assume a certain foundation of knowledge which I obviously don't have.
    I don't know if it matters to the answer, but just in case, my setup is:
    Denon 1403 receiver
    Boston CR2 center
    Boston CR6 (2 front and 2 rear)
    Sony SA-WM40 subwoofer
    Regardless of which I select, it sounds 100% better than it did before. I just want to be sure I'm using my equipment to it's top potential.
    Thanks in advance for your help.
    -Dan
  2. Sihan Goi
    Sihan Goi Second Unit
    Nov 2, 2001
    442
    Dolby Digital 5.1 is a compressed multichannel audio format that has audio information for 5 discrete channels(left front, right front, center, left rear and right rear) and a low frequency effects(LFE) channel for a subwoofer. The LFE is the .1 in 5.1, since it only takes up about 10% of the audio bandwidth. Dolby Digital 5.1, like DTS(Digital Theater Systems) has to be supported by both source media and hardware component, to be played. It is much like mp3 compression. You need an mp3 file and the decoder.
    DPL2 however, is a formula that tries to intelligently create 5.1 sound from a stereo signal. It works on any kind of source media, and doesn't need to be supported for it to work.
    For DVDs, definitely use Dolby Digital 5.1 whenever possible because its what the director intended for you, the audience, to hear, and will be the most faithful sound reproduction, unless there's an additional DTS track.
    For music however, DPL2 will be the obvious choice.
  3. BrentPollard
    BrentPollard Second Unit
    Dec 18, 2001
    445
    No DPL II is not better, it is different.You will use Dpl II for older VHS tapes or any other stereo broadcast off of cable tv etc. 5.1 will be sent from your DVD player or satellite dish via a coax or optical cable. My explanation may be a little thin but I think you will get the point.[​IMG]
  4. Rob Rodier
    Rob Rodier Supporting Actor
    Jul 11, 2002
    538
  5. Jack_V
    Jack_V Extra
    Dec 15, 2002
    20
    I agree, for stereo music sources, stereo mode sounds the best, its just personal taste and depends on your speaker setup.
    Also, receivers usually have more power in stereo mode.
    As mentioned, be sure to use DD 5.1 for DVDs with DD 5.1 audio, or DTS if your receiver and DVD disc permit.
    Some like Pro Logic 2 for stereo music/tv/VHS sources, see what you think...
  6. Barry BB
    Barry BB Stunt Coordinator
    Nov 28, 2001
    168
    "When I play a DVD, the receiver seems to want to use Pro Logic II"
    If your receiver is defaulting to PLII then it is not detecting a DD 5.1 signal so you have something wrong with your set up. Here are some things to check:
    1. Check that your receiver's input signal is set to auto mode. This way your receiver will automatically detect the signal it is receiving and play it back in the correct format.
    2. Your DVD player needs to be set to bitstream. Consult your manual for how to set up your DVD player.
    3. You should have either a coax or toslink connection between your receiver and DVD player. In your receiver set up verify that you have assigned the receiver's input to optical or coax.
  7. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    3
    5,110
  8. mark alan
    mark alan Supporting Actor
    Nov 19, 2002
    620
    Remember also that a lot of dvds have the 2.0 soundtrack as the first (default) track. You have to select the 5.1 track with your player
  9. David G Greene
    David G Greene Stunt Coordinator
    Jul 28, 2002
    120
    I like Pro Logic 2 for stereo music/tv/VHS sources better,but for DVD it's DTS or DOLBY DIGITAL.
    [​IMG]
  10. David Lorenzo
    David Lorenzo Stunt Coordinator
    Dec 12, 2002
    198
    Every one said it all already. I just want to add that PL2 is intended to expand a 2 or 4 channel source to 5.1 sound. Dolby Digital and DTS are, for the most part, already in a 5.1 format so the there is no need for PL2. Hope this helps.
  11. Barry BB
    Nov 28, 2001
    168
    Or he could be playing discs that only have a 2.0 soundtrack.
    That didn't even occur to me!
  12. Jeff Braddock
    Jeff Braddock Second Unit
    Jan 26, 2002
    306
    Also, (at least with my 1803) the receiver goes into PLII when the menu is coming up and all. It switches to DD or DTS when the movie actually starts. That could possibly be what is occuring here as well.
  13. Michael Reuben
    Feb 12, 1998
    21,763
    3
    5,110
  14. daniel socal
    Dec 27, 2002
    2
    Thanks to everyone that responded.
    As it turns out, those that were familiar with Denon were correct, it does default to Prologic II until the audio stream begins. I didn't see the behavior originally because I was testing with an old DVD that only had a streo track.
    Thanks again.
  15. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
