Dolby doesn't work correctly
Discussion in 'Beginners, General Questions' started by Tim_dan, Dec 22, 2003.
  1. Tim_dan
    Tim_dan Auditioning
    Dec 21, 2003
    6
    ok, i'm new to this and i'm sure i don't have the greatest system in the world, but i shouldn't have this problem. when i view a dvd in dts mode everything is beautiful. but when i use any type of dolby option on a dvd the sound crackles and the voices are out of sync. with my limited knowledge i've run out of ideas on what to do. this is my system:
    htib-Kenwood htb-206
    tv-jvc av32f734
    dvd-polaroid dvp1000
  2. Jack Briggs
    Jun 3, 1999
    16,738
    129
    How loud do you have your system running? As for A/V tracks being out of sync, this happens to some extent. Try stopping the player and then restarting it, which is the usual fix. Also, in your player's setup menu, make sure you have enabled Dolby Digital pass-through.
  3. Tim_dan
    Tim_dan Auditioning
    Dec 21, 2003
    6
    it happens even at low volumes. i don't have a dolby digital pass-through option. you mean on the dvd player, correct?
    these are my audio options: spdif/off, spdif/raw, spdif/pcm.
    it also has a downmix configuration with: vss, lt/rt, stereo, and off.
    there is a digital setup page with: op mode- line out or rf remod.
  4. Ed Moxley
    Ed Moxley Cinematographer
    May 25, 2003
    2,701
    Eastern NC
    Ed
    use the spdif/raw, if you're not already..........
    how long have you had it (system)?
    the DD decoder could possibly have a problem......
  5. Mark Shannon
    Mark Shannon Screenwriter
    May 27, 2002
    1,991
    It could be your DVD player, as my Hitachi did this as well (out of sync, not crackles in the sound). It turned out that it was simply outdated firmware on the player. Called Hitachi, and they sent an upgrade CD.
  6. Tim_dan
    Tim_dan Auditioning
    Dec 21, 2003
    6
    i went to polaroid's website and they had an upgrade available for download. it completely fixed the sound problems, but...now i have lines that keep popping up on the screen. this wasn't happening before.
  7. Mark Shannon
    May 27, 2002
    1,991
    What do you mean by lines? How often to they appear? Is it possible the disc you're using is dirty?
  8. Tim_dan
    Tim_dan Auditioning
    Dec 21, 2003
    6
    i tried a few discs and it happened on all of them. it's like static or interference or something. they only last a split second, but it's like bad reception. doesn't happen when i'm watching tv, only dvd, and it didn't happen until i updated the firmware for my dvd player.
  9. Mark Shannon
    May 27, 2002
    1,991
    Is it possible you loosened the cables or something similar when you updated the firmware? How exactly did you update it, anyways?
  10. Tim_dan
    Tim_dan Auditioning
    Dec 21, 2003
    6
    i guess that's possible.
    i went to the polaroid electronics website, clicked on downloads, and the only update they had was for my model. i followed their directions, burned it to a cd, and put it in the player.
  11. Johnny Ayala
    Johnny Ayala Stunt Coordinator
    Nov 13, 2003
    183
    Tim, what kind of connecters are you using from the TV to the DVD player? [​IMG][​IMG]
  12. Tim_dan
    Tim_dan Auditioning
    Dec 21, 2003
    6
    component cable.
