dolby digital preference
Discussion in 'Archived Threads 2001-2004' started by itai, Aug 6, 2002.
  1. itai
    itai Stunt Coordinator
    Jan 23, 2002
    221
    why is it that when a dvd with just 2ch (stereo) audio is playing, i cant choose dts-neo6?, the reciever defaults to prologic and that's that.
    is it because the sound engineers closed it with a dolby codec or something? becuase audio cd desnt have that preference.
  2. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    I noticed the same thing. My guess is when you have a stereo track on a DVD, it is typically DOLBY stereo, which is why certain modes cannot be selected. If your CD player is hooked up via analog, there is nothing to setup to even give you selections.
  3. Selden Ball
    Selden Ball Second Unit
    Mar 1, 2001
    412
    Selden
    Itai,
    Yes, the problem is that the digital audio bitstream coming from the DVD is Dolby Digital 2.0 encoded. The DSP chip in your receiver is spinning its wheels running the code that does Dolby decoding and can't apply any other DSP options.
    When playing 2-channel DVDs, you might consider changing the DVD player's internal audio output option so that it produces PCM (CD digital format) audio. Your receiver should be willing to manipulate a PCM signal in many ways. Most DVD players include PCM as a a digital output option in order to be compatible with older stereo receivers.
    Of course, you should have the DVD player's analog audio outputs connected to one of your receiver's stereo inputs, too. Then you can apply whatever DSP options are available for analog inputs.
    I hope this helps a little.
  4. DanielSmi
    DanielSmi Second Unit
    Mar 20, 2002
    455
    What kind of receiver do you guys have? I have the Pioneer VSX-49TX and I can select DTS Neo:6 with a Dolby 2.0 source I tested it with "Forbidden Planet." everything works fine for me.
    Daniel Smith
