rodneyH
- May 22, 2001
I recently got a new amp (marsh a400s)and as I was playing tonight, I noticed that there is a "hmmmmmm" coming out of my speakers, I disconnected my interconnects that come from my pre/pro, and it is still there, I didn't notice it before, It doesn't happen with my other amp (rotel). My rotel is running off a rotel line conditioner and my Marsh is direct into the wall outlet (but I use a 12V dc trigger from my pre/pro, the Marsh will not work by way of the power conditioner, so I have to plug it direct, ALSO that particular outlet has an "on/off" switch, like the ones used for lights (if that makes a difference??). I immediately went and checked my dads system (he is using Mc and Rotel amps) and his Mc and Rotel do the SAME thing but at a slightly lower volume (they are both plugged into the exact same type of rotel power conditioner. Also, The Hmmm doesn't get louder as the volume is increased, I don't get it??
So is this even a problem?? (it is a very powerful 200WPC amp)
Is is possibly b/c
1.NO line conditioner?
2.plugged into outlet with a "on/off" switch on the wall?
3.just the nature of that amp?
4.the 12v dc trigger switch is causing some type of leakage?
5.any other opinions??
it really isn't bad, I just want to make sure it is OK, and will NOT cause any damage, even when I listen to music at very low volume it isn't even noticable. I seem to remember hearing similar sounds at a high end audio store (using very powerful amps).
thanx for the advice!! (in advance)
Is is possibly b/c
