Does XBox support progressive scan...?
Discussion in 'Archived Threads 2001-2004' started by Jeff Holton, Dec 9, 2002.
  1. Jeff Holton
    Jeff Holton Stunt Coordinator
    Jul 19, 2002
    93
    ... and if it does, how do you switch it on?
  2. Scott Van Dyke
    Scott Van Dyke Supporting Actor
    Jan 21, 2002
    579
    Jeff,
    Most games for the box are in 480p or better. The box will not play DVD's in 480p, however.
  3. Jeff Holton
    Jul 19, 2002
    93
    Scott,
    Is there on option on the XBox menu to activate the progressive scan?
  4. Romier S
    Romier S Producer
    Sep 2, 1999
    3,526
  5. Scott Van Dyke
    Jan 21, 2002
    579
    I concur with Rom, Jeff. Once you hook-up your box with the correct cables as mentioned by Romier, you will automatically have new options on your dashboard.
  6. Keir H
    Keir H Second Unit
    Jan 4, 2001
    462
    Guys, I just picked up one last night. I tested it out a bit but was late so I crashed. I found that it looks good even with the standard cable hookups. I have a 47" Panny 16x9, by going with the HiDef pack, will I see a noticable improvement? Also does that pack or any other have coax out for Digital (DD) or only toslink? thanks!
  7. DonJ
    DonJ Second Unit
    Mar 5, 2002
    293
    Get the monster cables. I have the s-video montser pack and it was quite an improvment.
  8. Romier S
    Romier S Producer
    Sep 2, 1999
    3,526
  9. Scott "E"
    Scott "E" Second Unit
    May 3, 2002
    309
  10. Travis Kolesar
    Travis Kolesar Second Unit
    May 16, 2002
    291
    monster cable has a coax adapter available for their xbox cables, i think you can order it direct from them. too bad their xbox cables cost so much
  11. Romier S
    Romier S Producer
    Sep 2, 1999
    3,526
  12. Matt Weldy
    Matt Weldy Second Unit
    Feb 4, 2002
    335
    I have a question for you I have hdtv connector for my xbox and have it hooked up but no progressive scan option is available on my dashboard.
  13. Andrew s wells
    Andrew s wells Second Unit
    Nov 20, 2001
    449
    I have a question as well.. I have the toshiba 50H81, and the HD pack.. my question is, since I have seen people mention it when using a VGA box with the XBOX... if a game is running in progressive scan on my tv, doesnt that mean the dashboard (since it is interlaced) should not be visible if i go to that screen? wasnt sure if it was the same with VGA and HDTV. Please excuse my ignorance. :b [​IMG]
  14. Matt Weldy
    Feb 4, 2002
    335
    My tv only has two inputs for componet. One is 480i/480p and the other is 480p/1080i. When I had it plugged into the 480p/1080i input when the dashboard came up the screen got all messed up. Thats how I figured out the dashboard was 480i.
  15. Andrew s wells
    Nov 20, 2001
    449
    anyone who can answer my last question? [​IMG]
  16. Ike
    Ike Screenwriter
    Jan 14, 2000
    1,672
    The dashboard is fine no matter if you're running progressive or interlaced. I don't know on VGA boxes, though.
    The difference was big for me, and in fact can make or break a game's graphics. I played the Splinter Cell demo in 480p on my 53", and it was easily one of the best looking games I've every played, and expected it to look better when I played it on my 32" in 480i, because of the smaller screen size. When the game wasn't running progressive, the character's were much blockier, and clunkier looking. This is the biggest difference I've seen, but I'd bet that the people complaining about Splinter Cell's bland graphics aren't playing it in progressive scan.
    Overall, though, you'll just notice everything is "crisper".
