Does xbox support anamorphic DVD playback?
Discussion in 'Archived Threads 2001-2004' started by Conroy Tesa, Nov 26, 2001.
  1. Conroy Tesa
    Conroy Tesa Stunt Coordinator
    Jun 26, 2001
    167
    I have a 36 inch Wega xbr that supports anamorphic squeeze.
    How do I get my DVD's on my xbox to support this.
    I am using the HD pack with the xbox.
    do I change the video options in the setup screen to
    4:3?
    Letterbox?
    Widescreen?
    I'm confused!
  2. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    Go into setup and select widescreen. It plays anamorphic DVDs just fine.
  3. Shawn O
    Shawn O Stunt Coordinator
    Jan 31, 1999
    191
    Use the "Widescreen" setting.Also,make sure that your TV is set to 16:9 if required.Not sure how the Wega's work.Make sure that you are using the correct input,on my Sony 61hs10 only video5 suppors anamorphic squeeze.
  4. Conroy Tesa
    Jun 26, 2001
    167
    So if I switch it to widescreen on the xbox, it will only squeeze dvd movies and not games?
    Or do I have to change between 4:3 (games) and widescreen (movies)
    Sorry to sound dumb but I just picked up the remote today at lunch and want to test it out when I get home!
  5. Joel Mack
    Joel Mack Cinematographer
    Jun 29, 1999
    2,317
    Just set it to 16x9 and your XBox will work everything out on it's own. (ie. 4x3 games play in 4x3, and widescreen games play in widescreen.) [​IMG]
  6. Conroy Tesa
    Jun 26, 2001
    167
    Cheers!
