Does which input matter?
Discussion in 'AV Receivers' started by Justin_D, Jan 4, 2004.
  1. Justin_D
    Justin_D Stunt Coordinator
    Dec 27, 2003
    217
    By the title I mean, is there a difference in sound between plugging the audio outs on a cable box to the CD labled ports and the Video 1 ports? Or is it just the lables?
  2. Paul S
    Paul S Stunt Coordinator
    Nov 2, 2003
    93
    All audio inputs on your receiver are line level so it doesn't really matter which inputs you use. WITH ONE EXCEPTION The phono input should only be used with a turntable since it already has a built in preamp. Basically, use any audio input you like for any purpose except the phono input.
  3. Justin_D
    Dec 27, 2003
    217
    Thats good to know.
    Thanks.
  4. DavidLW
    DavidLW Stunt Coordinator
    Nov 21, 2003
    161
    Along with the Phono Input, watch out for the Tape In and Out. If you have a tape deck you would want to use the Tape Inputs as it let's you select what input to record from by using the Tape Monitor switch in front and selecting the other input with the main knob.
