Does this wire converter exist?
Discussion in 'Archived Threads 2001-2004' started by Josh Davidson, Dec 20, 2001.
  1. Josh Davidson
    Josh Davidson Stunt Coordinator
    Dec 7, 2000
    81
    My receiver has two digital audio inputs. One is for a coaxial cable and the other is for optical cables. However, both devices I would like to use digital audio for have optical outputs. Is there a such thing as a convertor that will convert one of the optical cables into a coaxial cable?
  2. John Kotches
    John Kotches Cinematographer
    Mar 14, 2000
    2,635
    Yes. I believe Audio Authority makes an inexpensive coax/toslink convertor.
    Fostex also makes one.
  3. Ashok
    Ashok Agent
    Dec 7, 2001
    37
  4. Robert_J
    Robert_J Lead Actor
    Aug 22, 2000
    8,296
    53
    9,110
    Mississippi
    Parts Express has one in their new catalog but not on their web site. I'll look up the part number and price when I get home. IIRC, it was less than $15.
    -Robert
  5. Josh Davidson
    Dec 7, 2000
    81
    Hey guys, I don't know if what was posted would work. I need to go from optical to coaxial. It looks like the stuff from parts express is the other way around.
  6. PomingF
    PomingF Second Unit
    Mar 4, 2000
    343
    Josh, looks like you can either get an optical-to-coaxial adapter or a multi-input optical switch. You can find both on Markertek.com with parts numbers AA977R & ADS-1000. You can use the search function with the part numbers.
    Btw, the prices ($57.99) for the AA977R & AA977T are wrong on their website for they are listed $37.99 in the catalog fact that it only costs $54.99 for the kit which includes an adaptor, power supply ($14.99) & cable make the error quite obvious.
    Good luck.
    PF
  7. Josh Davidson
    Dec 7, 2000
    81
    Does anyone know if any other site or retail location(preferable due to shipping costs) that carries a 6v 500ma ac-dc adaptor with a 1.7mm X 4.0mm end since Parts Express is out of stock?
