Does this exist??
Discussion in 'AV Receivers' started by DanielM, Dec 19, 2003.
  1. DanielM
    DanielM Stunt Coordinator
    Jul 5, 2002
    224
    a tubed home theatre preamp?? or a way to integrate a tube preamp/amp combo into a home theatre or some such??
  2. Dan Driscoll
    Dan Driscoll Supporting Actor
    Aug 1, 2000
    937
    2
    Sure. IIRC, Rockford Fosgate makes a tube AC-3 surround decoder and I'm sure they are not the only ones. But keep in mind that the actual decoding is still done with DSP chips. The tubes are typically used to amplify and buffer the output signals after they have been converted to analog.
    It isn't too difficult to add a 2 channel tube preamp to a home theater system, it is something I'm looking at right now. Some newer 2 channel preamps have an HT Bypass, that is routed around the gain stages and volume controls, directly to the output. But even it doesn't have a bypass you can still use a tube preamp with your HT system, you just have to work with 2 volume controls, the one on your digital pre-pro and the one on the 2 channel tube pre-amp. When you do your level calbibrations make sure you mark the volume setting on the tube preamp, so you can return it to the same setting every time you watch a movie.
  3. DanielM
    Jul 5, 2002
    224
    The car audio company????
  4. Dan Driscoll
    Aug 1, 2000
    937
    2
    Sorry, I sometimes forget the name changes. The home audio side is now called Fosgate Audionics. Here's a link to the tube decoder I mentioned, the FAP-V1.
  5. FeisalK
    FeisalK Screenwriter
    May 1, 2003
    1,245
    Dan,
    if that's the case, why would they leave out DD/DTS?
  6. DanielM
    Jul 5, 2002
    224
    this is not really an ac3 decoder or is it a preamp it is interesting though
  7. FeisalK
    May 1, 2003
    1,245
    I see.. i guess it only accepts 5.1 analog inputs, and stereo inputs (which the DPLII DSP can play around with)
  8. Billy Posey
    Billy Posey Second Unit
    May 15, 2001
    255
    I believe that back in the mid 90's ADA had plans to make a tube Home theater Pre-amp. It was shown in the early Home Theater Magazines and in the old video magazine. It had a thick glass face plate and had a window along the top window to allow for viewing the tubes. It was displayed in a similar way that car companies show off concept cars. I think it was planned to sold for 29000 dollars. I don't know if it ever made it to production, but it did look sweet. If can figure out how, I will scan the picture and upload it.
  9. Dan Driscoll
    Aug 1, 2000
    937
    2
    Damn, I'm missing a few lately. There is or was a tube output AC3 processor a few years ago. I was thinking it was the Fosgate, but obviously that was wrong. It didn't do DTS because at the time DTS was not a standard feature. I had a link to the manufacturer, I'll dig around and see if I can find it.
  10. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    I recall seeing an all-tube pro-logic pre-amp, i think on SMR during one of their show reports. But other than that.....
  11. Danny Tse
    Danny Tse Producer
    Nov 1, 2000
    3,185
    [​IMG]
    Here's the Fosgate Audionics FAP-V1
    BTW, Rockford owns MB Quart, Hafler, and NHT.
  12. Chuck Schilling
    Chuck Schilling Stunt Coordinator
    Jul 1, 2003
    129
    Danny, are you sure about that? I thought each of those brands, including Rockford Fosgate, was owned by Recoton.
  13. Robert_Dufresne
    Robert_Dufresne Stunt Coordinator
    Mar 30, 2002
    246
    DAniel
    Wy go for an antique, HT is the domain of digital processing and solid state. [​IMG]
  14. FeisalK
    May 1, 2003
    1,245
    Robert,
    DPLII isn't 'antique' [​IMG]
  15. Ed St. Clair
    Ed St. Clair Producer
    May 7, 2001
    3,320
    FeisalK,
    I do not think Robert was referring too DPLII as "antique".
    Although, it is, now that DPLIIx is here.
    I think he was referring to Tubes vs. Digital.
    To which I would ask him;
    Would you prefer to listen to first order or second order distortions?
    Do you prefer dry over liquid, in your audio presentation?
    Do you prefer electonic haze over detail?
    And, would you like your soundstage confined between the speakers or would you be more satisfied with a soundstage that expands beyond the speakers?
    Can anyone tell I am a Tube Fan???
