Does this circle jig exist?
Discussion in 'Archived Threads 2001-2004' started by Jim A. Banville, Apr 10, 2002.
  1. Jim A. Banville
    Jim A. Banville Supporting Actor
    Jun 20, 1999
    630
    I'm looking for some sort of jig that will attach to a jig-saw that will allow it to make a perfect cicle. I thinking that it would need only a straight metal bar that protrudes out from the side of the bottom plate of the saw (lined up exactly beside the blade). The other end could have a pin that fits into a hole at the center of the desired hole. This would allow the saw to spin around in a perfect circle. Does this exist?
    thanks
    Jim
  2. Jeff Mills
    Jeff Mills Stunt Coordinator
    Feb 8, 2002
    95
    Buy a router!
  3. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    Jim
    The jigs actually may exist, but a major problem with using a jigsaw is the blade flexing. Not a big deal with really thin material, but a definite issue with .75"-1.5" stock
  4. Jim A. Banville
    Jun 20, 1999
    630
  5. jeff lam
    jeff lam Screenwriter
    Jun 4, 2001
    1,798
    San Jose, CA
    Jeff Lam
    I have also built many boxes and cut out many holes for subs with a jig saw. I just got my plunge router and circle jig recently and it really is a much nicer/cleaner/accurate cut. It's an amazing tool and I don't know how I ever managed without it. In fact, my new Dewalt 621 plunge router is my new favorate tool. It used to be my one click wire stripper I got for free in the mail.
  6. ThomasW
    Nov 6, 1999
    2,282
    Jim
    I've been building speakers for 40yrs, I know how a jigsaw works. The blades flex side to side when making a cut in thicker material. It's impossible to prevent. It's a function of the pressure on the blade when it's being forced to turn. As a result the cuts aren't 'plumb'.
    If you have a router get the Jasper jig.
  7. Pete Mazz
    Pete Mazz Supporting Actor
    May 17, 2000
    761
    I don't know of a commercial unit, but it's pretty easy to cobble one together with some scraps. As long as you make sure the front of the blade is used for referencing the pivot point, you should be good. I have used 1/4" scrap for the base and 1/2" strips to enclose the base of the jigsaw. A little hot glue to put it together and you'll be in business.
    Pete
  8. Mike Strassburg
    Mike Strassburg Second Unit
    Nov 4, 2001
    421
    Can always use the DIY pegboard jig. Worked great for my sonosub! Do a search as someone posted a pic of his...
  9. Johnny Mo
    Johnny Mo Agent
    Aug 22, 1999
    43
    Sorry posted this in the wrong place.
  10. Marc Bodin
    Marc Bodin Extra
    Apr 8, 2002
    19
    If you have a good jigsaw and the proper blade, you can cut a pretty good circle out. Ive never had a need for a jig for my jigsaw. For smaller diameters try using a hole saw. A router makes TONS of dust on MDF, Id wear a mask if you go that route.
  11. Lee Weiss
    Lee Weiss Stunt Coordinator
    Mar 5, 2002
    73
    Jigsaw blades always flex when I use them. If you already have a router and plan on using the Jasper jig in the future, I would highly recommend it. I just got mine and cut my driver hole with ease. Not to mention, you would have some nice cutout circles which would make great party favors.
  12. Ron D Core
    Ron D Core Stunt Coordinator
    Mar 31, 2002
    158
    Haha, party favors and they're fun to roll down the street and watch dogs chase after them. When I went to get a router and jogsaw, I opted for the expensive jigsaw and no router. I would rather have one good thing two two peices of junk. Anyway, I just put a thin screw about halfway through the MDF at the center of the circle and loop two peices of bailing wire or coat hanger around the screw and then to the front and back of the jigsaw. You'll have to keep the wires staight and tight otherwise the circle will be all messed up. Talk about ghetto fabulous.
