Marc Bodin
Grip
- Apr 8, 2002
Hi there, I am new to the home theater game, I have spent most of my time focusing on car audio. Basically, I just like fabrication and really good sound, whether it be mobile or not.
I have been told that all speakers in a 5.1 setup should be the same make and model for best results. I understand why this is important for satellites, but does it apply to the sub as well?
I would like to make my own system, and was thinking of a kit possibly, but for a sub I would like to use a JL Audio or Image Dynamics 12" or 15".
In a kit should you use the subwoofer they suggest, or is this one area where we are free to play? Do you have to do some type of level matching with the satellites and the sub?
Also, I have looked at the Audax home theater kit. Can you suggest some other HT kits to look at?
Marc
Marc
