The on screen display (volume and other displays) only works through the S-Video or composite video outputs. If an input signal is put to both the S-Video and the composite at the same time it will output only to the S-video output.
Bob
I have the monitor (TV) connected to my 3802 through the composite output (temporary) and I don't get an onscreen volume display. Bob, were you responding to my post?
---Is it still advisable to use "Monitor Out 2" on the 4802, to avoid video interference?---
If you want to bypass the OSD you can use the monitor 2 outs. I have not noticed any signal degradation however with monitor 1 outs on my VPL-VW10HT on a 110" screen.
Here is what the manual says about the OSD:
NOTES:
• The on-screen display signals are not output from the video signal MONITOR OUT-2 (yellow) or S-Video signal MONITOR OUT-2 jacks.
• The on-screen display signals are not output from the color difference (component) video signal MONITOR OUT jacks.
• For 4 above, the on-screen display signals are output to the VIDEO MONITOR OUT-1 video signal output jack (yellow) if the monitor TV is
not connected to the S-video MONITOR OUT-1 video signal output jack.
You can download the manual in PDF form from Denon's web site if interested.
Bob
So how different is this than previous Denon models? I only use the S-Video Monitor Out 1 for the system setup. This was for the 5700, the 4800, the 3802 and the 4802. I prefer not having the volume displayed on my monitor...although I understand wanting to have a choice in the matter.
------------------ Link Removed My Home Theater Pics My Equipment List My DVD Collection Link Removed
I can't believe the on-screen volume display isn't output via the component monitor out jacks. Until they fix this, the on-screen volume display feature is useless to me. This pisses me off.
Patrick: you're right! I keep my Denon outputting component video about 90% of the time so volume control on s-video/composite video doesn't buy me much of anything. I heard the reason is they want to keep the signal path for component video as pure as possible. To my knowledge no a/v receivers output menus and such over component video.
