Does the BFD have Subsonic Filter???
Discussion in 'Archived Threads 2001-2004' started by Jim Lowe, Nov 1, 2002.
  1. Jim Lowe
    Jim Lowe Auditioning
    Oct 14, 2002
    6
    This is probably a dumb question but i've looked and can't find the answer. Do I need to buy a "rumble box" in addition to buying a BFD for use with my subwoofer(going to be SVS 16-46CS+)??? Or is there some setting where it cuts out the way down low information right on the BFD making a "rumble box" moot? Thanks.
    Jim
  2. Ronald Volkman
    Sep 18, 2002
    29
    No..the BFD does not have a rumble filter. You could put a deep cut at 20hz (lower limit of BFD), but it would be too high and would affect the bottom octave.
    Ron
  3. Jim Lowe
    Oct 14, 2002
    6
    Thanks for the reply, so I guess this means I have to get both, running the sub from my reciever to the "rumble box" to the BFD to the Amp to the Sub. Whew, that's a lot of stops on the way to sound!!!
    Jim
  4. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    Is there such thing as a "rumble" box? Always bothered me that the BFD didn't have this. Reasonably priced?
  5. Jim Lowe
    Oct 14, 2002
    6
    They have a rumble box at SVS Website, it's around $159 if you buy an SVS subwoofer, and around $200 if you buy it separately. It has several subsonic filters at 15, 20, and 25. It also has a variable phase control on the box.
    This is the link.
    http://www.svsubwoofers.com/marchandsubsonic.htm
    Jim
  6. Kevin C Brown
    Aug 3, 2000
    5,712
    Jim- Thanks! I was hoping for less than $100, but now that I know such a thing exists, I'll have to check it out.
