Does the 43TX and 45TX accept spades for speaker connections?
Discussion in 'AV Receivers' started by Stephen Hopkins, Aug 11, 2003.
  1. Stephen Hopkins
    Stephen Hopkins HW Reviewer
    Jul 19, 2002
    2,598
    I'm getting ready to purchase either the Pioneer Elite 43TX or 45TX. I'm also in the process of building some DIY speaker cables. I've already terminated the speaker end of the cables with spades. I'm waiting on terminating the receiver end of cables depending on whether or not the receivers i'm looking at accept spades. If it doesn't accept spades, i'm going to need to find banana plugs that will fit on 6awg stranded coper cable.
    Thanks [​IMG]
  2. David Judah
    David Judah Screenwriter
    Feb 11, 1999
    1,479
    No, there are plastic guards that would prevent full contact with spades. Banana plugs are gonna be the way to go with those models.
    DJ
  3. Stephen Hopkins
    Jul 19, 2002
    2,598
    Thanks for the quick response... only problem is the only banana plugs i've been able to find to fit 6awg cable cost $14.44 EACH.
    Shopkins
