Hello All:
I'm getting conflicting info on the Samsung HLR6168W 1080p DLP HDTV. According to the user manual:
"This TV receives a signal input and converts the signal
into 1080p through signal processing.
Although the resolution of this TV is 1920 x 1080, to
watch TV with a higher visual quality and sharpness
than a conventional TV, you can watch TV in a better
visual quality when the input signal resolution is
1080p.....To view TV in the best visual quality of 1080p,
connect to a PC whose graphic output is WUXGA
(1920 x 1080)."
I also read that the HLR6168W was one out of only 2 current TV's that will accept a true 1080p native resolution.
However, another source has stated that there are no true HDTV's that will accept a 1080p resolution.
I'm hoping to get an iScan HD video scaler to improve SD Satellite PQ for the TV. The iScan provides a 1080P signal through it's VGA output which I hope to feed into the 6168.
Would someone kindly confirm if the HLR6168W can accept 1080p input via VGA.
Thanx
(1920 x 1080)."
Thanx
