Lewis Besze
- Jul 28, 1999
There is a couple of issues here,some been mentioned already.
Not all receivers use it's BM in 2ch[stereo] mode,in that case the salesman's way is right.
By design "fault" some receivers don't "fold" all of the LFE info[output] into the mains,when selected "no" for sub "large" for mains.I have tested this on 2 older models [Denon 3600 and Sony 777ES],both were about 4db shy compare to the LFE and main separate.we used RTA with a PC and soundcard].Maybe newer models do better?
When selected small on all other channels but the mains,and no sub,then all bass below xover point will go to the mains.
Also I wouldn't hook up a sub that douesn't have any highpass crossover built in for the speaker level outputs.Most don't have this feature,and the ones that have usually a high fixed point [100hz],with a shallow 1st order slope filter 6db/octave,which is unsuitable for many speakers,that was suppose to be used in this configuration.
Most subs only use lowpass crossovers,many are continiously variable,but the idea of BM is bass redirection to speakers that can handle bass best,running mains unfiltered and trying to blend a sub with the lowpass filter alone is a half ass job IMO.
To sum it up,if your receiver use it's built in BM in all listening modes, then the Sub line level out is the best way to hook up the sub.
