Does LD and VHS have upc-numbers or similar ids?
Discussion in 'Archived Threads 2001-2004' started by KristianH, Nov 14, 2002.
  1. KristianH
    KristianH Agent
    May 9, 2001
    44
    Hi everyone.
    A quick and short question as stated in the topic.
    Since all(?) dvds have a upc-number that is unique, is this the same with LD and VHS?
    Regarding legitimate VCD's does this apply also?
  2. Troy LaMont
    Troy LaMont Supporting Actor
    Mar 11, 1999
    849
    • Does LD and VHS have upc-numbers or similar ids? Yes.
    • Since all(?) dvds have a upc-number that is unique, is this the same with LD and VHS? Yes.
    Troy
  3. Jesse Skeen
    Jesse Skeen Producer
    Apr 24, 1999
    4,486
    334
    4,110
    I noticed the catalog number of the widescreen "Ferris Bueller's Day Off" laserdisc (which is in the WRONG aspect ratio!) is the same as that of the DVD (which is in the right ratio.)
  4. Jeff Kleist
    Dec 4, 1999
    11,267
    All UPC numbers are NOT unique, but they are most of the time
    Some VCDs have UPC, some don't. Most often UPC codes are found on the spine card if there is one. The only way to really be pretty sure that a VCD is legit is to do your research or buy them from trusted retailers like DDDHouse
  5. KristianH
    KristianH Agent
    May 9, 2001
    44
    Many thanx guys.
    [​IMG]
  6. JJR512
    JJR512 Supporting Actor
    Dec 11, 1999
    619
  7. JJR512
    Dec 11, 1999
    619
    Just wanted to add, for clarity, that every different variation of a product should have its own unique UPC code. For example, if there are separate widescreen and fullscreen versions of the same movie, which are released at the same time and are otherwise exactly the same other than the aspect ration, they should have different UPC codes. Or for laserdiscs, if a movie is released in two otherwise identical version except one is CAV and the other is CLV, they should also have their own unique UPC codes. Having different codes allows the manufacturer to track how many of each variation are being sold, which helps them decide how many of each to make, and may lead them to conclude that a particular variation doesn't sell well enough to produce anymore, for the specific title or for any title (or product, whatever it may be). It also allows stores to keep track of each unique inventory item so they can know what to reorder.
  8. Troy LaMont
    Mar 11, 1999
    849
