Does Gamecube have an S-Video Cable?
Discussion in 'Archived Threads 2001-2004' started by Dome Vongvises, Aug 26, 2002.
  1. Dome Vongvises
    Dome Vongvises Lead Actor
    May 13, 2001
    8,172
    I've looked everywhere for a Gamecube Cable with an S-Video Component. Hell, I can't even find a Monster cable!
  2. felix_suwarno
    felix_suwarno Screenwriter
    Dec 2, 2001
    1,523
    i am using an svideo cable. for component video cable, purchase it directly from nintendo.com.
  3. dave_brogli
    dave_brogli Screenwriter
    Mar 30, 2002
    1,021
    if you have a sam goody I know they got them there
  4. Dome Vongvises
    May 13, 2001
    8,172
    I'll probably have to get them there this weekend. Thanks.
  5. Erich_S
    Erich_S Extra
    May 29, 2000
    21
    Also, note that the S-video cable for the N64 works on the Gamecube. As I was carrying my gamecube S-video cable up to pay for it, I noticed "Also works for N64!" on the box. I figured that the reverse was true for my unused N64 cable sitting at home so I put it back, went home, and tried it. Sure enough, the GC works just fine with the old cable and I saved $10.
    Erich
  6. DonRoeber
    DonRoeber Screenwriter
    Feb 11, 2001
    1,849
    SNES, N64 and GameCube have all used the same AV connector, so any S-Video cable set for any of them will work. I got mine awhile ago, I think I got the madcatz one (it's purple). Works fine. Big improvement over composite.
  7. Iain Lambert
    Iain Lambert Screenwriter
    Jun 7, 1999
    1,345
    Bear in mind, oh European Gamecube owners, that this isn't the case for PAL ones. Nintendo, at the very last minute, removed the SVideo capability from the PAL Gamecube, as it was the easiest way of them supporting RGB instead. So none of those third party leads worked.
