Does flat sub cable (RCA type) exist?
Discussion in 'Archived Threads 2001-2004' started by Jose G, Nov 19, 2002.
  1. Jose G
    Jose G Supporting Actor
    Aug 18, 2002
    568
    I know there is flat speaker wire- I use it to run wire under the rug, but is there such a thing as flat sub cable for the LFE hook up?
    One more question: If my receiver's bass management sends the LFE to the sub at 100 Hz (when speakers are set to small) and my main speakers go down to 50Hz, should I use a left/right speaker connection hook up to the sub and use the crossover on the sub instead of the LFE/RCA connection?
  2. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    Indeed it does. One can purchase RG6 say that's flat and typically it may be used for running under a window. As to commercially made cables for your purpose, perhaps places like partsexpress, markertek, etc. might have what you're looking for. Of course, it'll require a non standard RCA but those places should be able to hook you up.
  3. Jose G
    Aug 18, 2002
    568
    Thanks, Chu. I'll look into RG6 and see if there's a RCA type adapter I can hook on the end.
  4. Frank Carter
    Frank Carter Screenwriter
    Mar 12, 2002
    1,187
    Those RCA adapter's are available at Radio Shack for a little over a buck.
