Does DVD RW have to be played/read in DVD RW drive or will regular DVD drive work
Discussion in 'Computers' started by Mike_ROG, Oct 23, 2003.
  1. Mike_ROG
    Mike_ROG Extra
    Jul 7, 2003
    20
    I know when it comes to CD-R/RW you have to play/read a CD-RW in a RW drive only.
    Is it the same way for DVD's? If I burn a DVD+RW can it be used in a regular DVD player/reader on a PC or does it have to be read in a DVD RW drive only?
    Mike
  2. John_Bonner
    John_Bonner Supporting Actor
    Oct 25, 2000
    664
    I backed up a ton of stuff onto DVD RW (not sure if it was + or - though) then put the DVD into my laptop's non-RW DVD drive and I was able to read and copy the files.
  3. Rob Gillespie
    Rob Gillespie Producer
    Aug 17, 1998
    3,632
    5
  4. Mike LS
    Mike LS Supporting Actor
    Jun 29, 2000
    838
    Actually, most CDRW discs can be read in any CD-ROM drive. I think the CDROM drive has to read over a certain speed, and it can also depend on the program used to write the disc (especially if you use a Win Explorer writing program).
    I would think DVD would work the same way.
  5. Rob Gillespie
    Aug 17, 1998
    3,632
    5
    You might find an old CD-ROM that can't handle rewritable discs, but nothing produced in the last few years should have that limation.
    Whether a disc can be read is more likely to be limited by the format it was written in. Use the standard Joliet or ISO9660 formats and it should be fine.
