Julian Reville
- Aug 29, 1999
They can both sound very good, but I just love it when the little dts logo on my DSP-A1 lights up.
If you want a good example, Saving Private Ryan DD vs the full bitrate DTS. No question, the DTS version sounds better.The DTS mix has also been cooked for DTS' strengths. DQd on those grounds from a fair comparison
I personally have noticed that when I play a DD dvd with my volme at 30 I have to turn it down to 27 when I put a DTS dvd in right after it.
The first time it happened I thought I accidently turned the volume up but it was the disc. For the DD dvd to sound as loud as the DTS dvd I would have to turn it up to 33. And on my system that 3 digit difference is big.
I always wondered if that was only on mine system. Has nobody else experianced this? I always watch DVDs with my volume on 30 and that is not too loud for my girlfriend, but DTS dvd's I always have to turn it down by 3, with out fail.This is because most DTS soundtracks are played back 4dB or more louder than their Dolby Digital counterparts. Louder is always perceived as better, which makes direct comparisons of the two formats extremely difficult, even if both are present on the same disc.
Adam
Just about anyone can encode a DD 5.1 track, but you can't do this with DTS AFAIK. I was under the impression that the DTS tracks have to be done by DTS, no?Nope, DTS, realizing that studios weren't going to pay their mastering fees on a lot of titles developed encoding software to sell. That's why there's been so many complaints that many DTS mixes sound just like DD, the studios encode from the same master instead of DTS' cooked one.
This is also why there are tons of DTS bootlegs showing up, the pirates record the 5.1 DD output and re-encode it as DTS
Bottom line- All things being equal, the ACTUAL difference is miniscule at best between the 2 formats, so there's no reason to fight over it.
Jeff, If the DTS SPR is "cooked" to make it sound better then please tell me why the LOW BITRATE dolby digital on the LaserDisc sounds noticably better than either the DD or DTS DVD?Depends who you ask.
I thought that the LD had a smoother top end,a beefier lowend.
While it's obvious that the two DD tracks were sourced from 2 different masters[I have no idea why!],the lower bit rate DD actually rolls off the highs gradually above 15khz,which can account for the "smooth" top end,the low end however can't be bit rate affected.
I personaly preffer the DTS DVD.
