Does DTS actually sound better than DD 5.1?
Discussion in 'Archived Threads 2001-2004' started by Daniel Mc, Jun 13, 2002.
  1. Daniel Mc
    Daniel Mc Agent
    May 5, 2002
    37
    I hear so much about how great certain DVD's sound with the DTS soundtrack. Is this really true? If so, what makes a DTS soundtrack sound better than a DD 5.1 track? Can you hear more detail or what?
  2. Adil M
    Adil M Supporting Actor
    Nov 21, 2001
    922
    This has been discussed many times before, but I'm going to toss my two cents in that I can't hear the difference after making sure they are the same volume on all three of my Superbit DVD's. Go figure. I can tell the difference between mp3's and cd's most of the time.
  3. Jonathan Smith
    Jonathan Smith Stunt Coordinator
    May 26, 2002
    122
    I think the theoretical side of it is that DTS uses considerably less compression (and therefore takes up much more space) than DD 5.1, so more of the original sound is on the disc. Whether or not it makes an audible difference is a big debate.
  4. Matt Stone
    Matt Stone Lead Actor
    Jun 21, 2000
    9,063
    Matt Stone
    Yes...the basis for the "quality" of DTS stems from the fact that it uses quite a bit less compression as DD.
    That being said, there are some DD tracks that sound better than their DTS counterparts. The Rock: CC comes to mind...
  5. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    It has more to do with the mastering than the fact that a track is DD or DTS. Well mastered DD tracks can sound just as good as DTS. However, of the movies that I presonally consider to have great sound, a large percentage of them are DTS and or ES.
    If you want a good example, Saving Private Ryan DD vs the full bitrate DTS. No question, the DTS version sounds better.
    The gear used can be a factor also.
  6. Andrew_Ballew
    Andrew_Ballew Second Unit
    Feb 21, 2002
    294
  7. Al B. C
    Al B. C Supporting Actor
    Apr 25, 2002
    644
    As much as I have tried, I really don't hear any appreciable difference.
    If there is a difference it's slight to be sure, and I don't think warrants all the hubbub that surrounds (no pun intended [​IMG] ) DTS encoding.
  8. Eugene Hsieh
    Eugene Hsieh Supporting Actor
    Jun 30, 1997
    550
    Probably much of it is the mastering. I have heard both excellent DD5.1 and excellent DTS.
    It's pretty common to hear truly terrible DD tracks, but it's unusual to hear absolutely terrible DTS.
    ie. every 2nd movie from every second film company is DD, but it tends only to be the big budget Hollywood blockbusters with DTS.
  9. Andrew_Ballew
    Feb 21, 2002
    294
    About the only difference I can hear at all between the two formats is a greater mid-range prescence or perhaps even coloration is sometimes found on DTS encoded tracks. A good example that I can think of at the moment is the Shrek DVD, which contains the same mix encoded in both formats. This is not the rule, though- it does not always work out that way.
    Andrew B.
  10. chella
    chella Stunt Coordinator
    Apr 16, 2002
    66
    The argument of less compression means higher quality is not valid. It is quite possible that the DD compression scheme is much more efficient than the DTS.
    It is absolutely not possible to state that one scheme is better than another, without using the same source mastered in both formats, using the same equipments, in a blind A/B comparison. Given the complexity, I think that is not possible, so the DTS and DD debate shall continue [​IMG]
  11. Craig W
    Craig W Second Unit
    Jul 28, 1999
    445
    Run for cover!!!!!
    Seriously, the other thing to take into consideration is the CODEC. Dolby has been around much longer than dts and had the money to develop a codec that is designed around the way we hear. Dts on the other hand uses a generic CODEC that has been modified to support audio.
    Flame suit ON
  12. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
  13. Ken Garrison
    Ken Garrison Supporting Actor
    Jun 1, 2002
    543
    When I was at my Uncle's house last summer, I watched a DVD of Roy Orbison Black and White night. I compared the DTS to Dolby Digital and the DTS actually had more of a cleaner, more stereo seperated sound. It seemed to have a lot better separation between the front and rear channels. Since I only have a Pro Logic system, I don't really care. But when I finally get a Dolby Digital/DTS system, then I'll make sure I select DTS as my audio track since I want the best audio I can get. I hope someday, they'll starting selling DD/DTS/SDDS systems for the home. SDDS is 7.1 audio and wouldn't mind having that. That would ROCK!!!
  14. Greg Haynes
    Greg Haynes Supporting Actor
    Oct 22, 1998
    577
    Basically if there is a choice between DTS or DD I will always pick the DTS soundtrack.
  15. Jed M
    Jed M Cinematographer
    Oct 2, 2001
    2,029
    Yes [​IMG]
  16. Bob_Wilson
    Bob_Wilson Agent
    Jul 28, 2000
    46
    Since you asked for an opinion about a highly debated topic, and since everyone has an opinion (like certain parts of their anatomy), here's mine:
    The difference between 5.1 and DTS is very subtle. Where I notice the difference is in the detail, the separation, and clarity especially in the low level sounds. While I am sure the difference can be measured, I do not think any frequency plot or o-scope trace would mean much.
    If you really want to perform a "valid" test, load a DVD with both 5.1 and DTS, give the remote to someone else, and sit back and close your eyes. Let that person select if it is going to be 5.1 or DTS, turn the volume down to zero and start the movie.
    Once the recognizable audio logo is finished, have the other person turn the volume back up. Keep your eyes closed and just listen. Repeat the process several times allowing the other person to select what sound track you are going to hear. I would suggest you try several different DVDs because even though DTS exactly reproduces the original sound track, some DVDs sound better in 5.1.
    Good listening, and let us know what you think!
  17. BrentPollard
    BrentPollard Second Unit
    Dec 18, 2001
    445
    Is the DTS version of Saving Private Ryan not full bit rate DTS?[​IMG]
  18. Adam Barratt
    Adam Barratt Cinematographer
    Oct 16, 1998
    2,343
    110
    Adam
    No. It's a 'half bit-rate' (754kbps) DTS soundtrack.
    Adam
  19. Reginald Trent
    Reginald Trent Screenwriter
    Feb 18, 2000
    1,313
    Irrespective of how the end result is obtained I tend to prefer DTS over Dolby Digital.
  20. Adil M
    Nov 21, 2001
    922
    The way I test it is by hitting the audio button on the remote while playing a superbit dvd. It switches automatically between DTS and DD. It's quick and automatic.
