Does Avia have individual test tones (15Hz-100Hz)
Discussion in 'Archived Threads 2001-2004' started by Jon_H, Nov 30, 2000.
  1. Jon_H
    Jon_H Stunt Coordinator
    Feb 22, 2000
    59
    I have Avia and cant seem to find individual test tones (like from 15Hz up) of low frequecies to test my Sonosub with. I see a sweep of tones, but it goes very fast. Can anyone point me in the right direction?
    Regards, JON
  2. Timmy
    Timmy Stunt Coordinator
    Sep 22, 1998
    160
    No, Avia does not have anything but that LFE sweep that indeed goes by too fast.
    Borrow an audio generator from a friend; you can select any freq you want and hold it there as well.
  3. John E Janowitz
    John E Janowitz Second Unit
    Oct 30, 2000
    445
    just a quick note on the test tones. The BassZone test CD that I put together for those on the basslist a couple years ago now does have individual sine waves, as well as warble tones. Here is a link to the page with the complete track listing of what's on it:
    http://www.stryke.com/diydrivers/shop/testcd1.htm
  4. Patrick Sun
    Patrick Sun Studio Mogul
    Jun 30, 1999
    38,777
    492
    9,110
    Count me in as a user of the BassZone CD, it comes in handy, and it's amazing what low frequencies at high SPL can do to ya! Wear ear protection if you plan on testing for low frequencies at 95dB or higher for long periods of time. It may not feel like you are damaging your hearing, but you will.
    PatCave ; HT Pix ; HT Gear ; Sunosub ; Pat's DVDs ; Pat's LDs
  5. TerryC
    TerryC Stunt Coordinator
    Oct 19, 1999
    218
  6. Keith Outhouse
    Keith Outhouse Stunt Coordinator
    Feb 2, 1999
    91
    Anybody use NCH Tone Generator from www.nch.com.au/action/index.html ? I recorded a slew of .wav files and burned a CD. Seems to do the trick, but I wonder how accurate (db wise) it is.
  7. Andrej Dolenc
    Andrej Dolenc Stunt Coordinator
    Jul 22, 1998
    249
    Keith,
    I haven't used that program (though I did see it out on the net), instead I downloaded SpectraPlus (30 day eval), used it's signal generator functions to create a bunch of sweep and individual frequency WAV's. Haven't burned it on a CD yet, it's been on the list of things to do for a couple of weeks..
    Andrej
  8. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    Keith
    The NCH tone generator is quite accurate with any normal sound cards.
    It's a great little program, it's unfortunate more people don't use it.
    I wish they would add pink noise, it's better for audio than the white noise option.
    It's the only program that I know of the will generate EXTREMELY low tones.
    Dangerous if people use the square wave function or use TOO low a test frequency
  9. Timmy
    Sep 22, 1998
    160
    BassZone CD, NCH tone generator ....
    Has anyone confirmed that the CD tones were recorded "totally flat" in their amplitude....... across the entire range?
    Same with the NCH generators output ?
  10. David Emery
    David Emery Auditioning
    Sep 12, 2000
    Cool Edit Pro has tone and pink noise capabilities.
  11. Steve Owen
    Steve Owen Second Unit
    Jan 7, 1999
    416
  12. Sam C
    Sam C Stunt Coordinator
    Apr 30, 2000
    115
    Another great set of discs are the Autosound 2000 test discs ... Not sure how familiar you may be w/ Car Audio but the guy who produced these discs is Richard Clark who was King Midas of Autosound ... You can get this set of 5 discs for 25 bucks I think ... Alot of it is Car based but there's some very useful stuff on them for home audio ...
    He can be reached at [email protected]
    "I will drop-kick those f#$%ing dogs if they come near me."
    Frank T.J. Mackey ... Magnolia
  13. John E Janowitz
    Oct 30, 2000
    445
    Timmy writes:
    "Has anyone confirmed that the CD tones were recorded "totally flat" in their amplitude....... across the entire range?"
    Yes, the tones on the Basszone Test CD were all recorded at 0dB full scale. After the problems that Stereofile had with one of their test CD's and the warble tones, I made sure that all my tones were matched in level. They are recorded at full scale though, so go easy on the volume and ease into things.
  14. Tim Christianson
    Sep 30, 1998
    17
    John,
    Which Stereophile test CD's had the level problems?? I have been using Test CD #3 for over a year now to tweek my E.Q. and have never heard that the Stereophile Test CD's had mis-matched levels.
    Please elaborate.
  15. Robert Fellows
    Robert Fellows Stunt Coordinator
    Apr 5, 2000
    67
    Remember that when one is doing sweeps, that the frequency response of the RS SPL meter isn't very flat...dropping off below 100 hz and above 2 khz.
    Usually the "flatness" of the frequency response doesn't matter too much (pink/white noise), but with sweeps, it really comes into play.
    There is a frequency response correction chart I'll e-mail to anyone who wants it...just e-mail me.
    Bob
    p.s.: This advice is worth exactly what you paid for it...
  16. Ellen
    Ellen Stunt Coordinator
    Jan 8, 2000
    142
    Ellen
    Any of you getting any slight pops with the tones you've generated? I've tried both the NCH Tone Generator and Cool Edit and there is always a slight pop at the very beginning and end of generated tones. This occurs when I playback the tones on my PC and also after having burned the tones to CD and played them on my CD player.
  17. Chris Hussak
    Chris Hussak Auditioning
    Oct 27, 1999
    9
    Terry C,
    I just got my BFD last week...VERY anxious to start playing, so I went to download the step tones from your site http://members.tripod.com/~terrycthe...um/page12.html but couldn't get them to download. My Miocrosoft Media Player kept popping up when I hit the link and gives me an error that the file could not be found...am I doing something wrong? Is it still available for download?
    Thanks in advance!
    Chris
  18. Julian Data
    Julian Data Second Unit
    Oct 5, 1999
    408
    The Stryke BASS CD is worth every penny in gold! [​IMG]
    John,
    Are there any plans on implementing a 6 cycle tone burst signals in the future?
    jd
  19. derek
    derek Second Unit
    Dec 20, 1998
    494
    John,
    Also can you gives us details on the upcoming vol 2 and vol 3 test cds? What will they contain, when they will be available and how they 'compliment' the current vol 1 release?
    Derek
    Surround EX FAQ: http://www.geocities.com/Heartland/P...urroundex.html
  20. Shawn O
    Shawn O Stunt Coordinator
    Jan 31, 1999
    191
