Does anyone make flat RG6?
Discussion in 'Archived Threads 2001-2004' started by Stephen P, Sep 8, 2001.
  1. Stephen P
    Stephen P Auditioning
    May 22, 2000
    6
    RCA has a short-run, flat co-ax which it says is "perfect" for connecting inside and outside cables for satellites under windows, etc. BUT, it doesn't mention if its RG6 or not. A google search turned up some combination wire (coax, phone, networking,etc. called "ribbon", I think), but I think that's a little much for me.
    I seem to remember hearing about a device you attached to each side of the glass (in my case, a sliding door) and it passed the signal through. Is this still around, or was it a bad application that has since died?
    Anyone have any ideas?
    Thanks!
  2. Glenn Overholt
    Glenn Overholt Producer
    Mar 24, 1999
    4,203
    If it is for satellites, then it has to be RG-6. (They know that). I once ran regular RG-6 from my balcony to inside by looping it around the sliding glass door. (The outer, sliding door had a rubber bumper at the end, so if it was opened all the way, the cable wouldn't get squished). It took more length, but worked perfect. Be creative!
    Glenn
  3. Ken Winders
    Ken Winders Extra
    Feb 25, 1999
    15
