VicQ
- Aug 19, 2001
My receiver doesn't automatically adjusts the surround delay as newer receivers do. The default delay right now is 20ms for dolby prologic and 5ms for dolby digital and dts. After almost 3 years I decided to play around with the delay and noticed that the soundfield cohesion and front to back and back to front panning is much better if I reduce the delay. My fronts are about 12 ft away and the surrounds are up and to the sides of the listening position about 6 ft away. I was under impression that you delay 1ms for every feet, but since that's about how I had it set up for the last couple of years, I always noticed that the sond seemed to jump when front to back panning was present. Now that I'ved reduced the delay, this is not the case. I know there's a correct formula somewhere. Any help?
-Vic
-Vic
