Dobly pro logic ?
Discussion in 'Archived Threads 2001-2004' started by Ryan L B, Mar 1, 2002.
  1. Ryan L B
    Ryan L B Supporting Actor
    Feb 5, 2002
    870
    When ever I watch a vhs tape, with pro logic on, it only comes out of the center chanell, even with brand new tapes, (I only get vhs if I can't get it on DVD or am too lazy to re purches the same movie.)
  2. Adam Barratt
    Adam Barratt Cinematographer
    Oct 16, 1998
    2,343
    110
    Adam
    Do you have a hi-fi stereo video? If your video is a mono model, video soundtracks will be heard only from the centre speaker.
    Dolby Pro Logic requires a stereo soundtrack to work.
    Adam
  3. Tom Weeks
    Tom Weeks Stunt Coordinator
    Aug 23, 2001
    73
    Have you gone into the VCR's menu and chosen stereo or Hi Fi audio?
  4. Ryan L B
    Feb 5, 2002
    870
    I have a samsung dvd/vcr combo player and it always playes though the center channel. Well then again, I have only tried Raiders of the lost ark, a non hifi, Wrestlemania video and the Stupids which is in hifi stereo. I'll check to see if the hifi option is on.
  5. Richard Travale
    Richard Travale Producer
    Feb 27, 2001
    3,425
    12
    The Island, Canada
    Rich Travale
    You may want to double check your receiver to make sure you are in Pro-logic rather than 3 channel stereo.
  6. Ryan L B
    Feb 5, 2002
    870
    I don't know how to turn pro logic off in the first place. I have a Sony home theater in a box that sells for $399
  7. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    If it is coming out of the center only, it is getting a mono signal. Even if you were in 3 stereo, a stereo signal would be simply across all 3 channels.
    Sounds like that combo unit only passes mono signal. I would check the manual and see if it is supposed to pass stereo (don't just asume if it has 2 audio outputs that it is passing stereo).
  8. Ryan L B
    Feb 5, 2002
    870
    My player has either A.F.D which is with 2 channels with the subwoofer or just 2 channel without the subwoofer.
  9. Vince Maskeeper
    Jan 18, 1999
    6,499
  10. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    3
    5,110
  11. Ryan L B
    Feb 5, 2002
    870
    Yes I do have the samsung model. Also I get DVD in its regular playback from whatever the original sound is. I just tried an original vhs version of T2 form 1991 and it was only out of the center channel.
  12. Larry Hoffman
    Larry Hoffman Stunt Coordinator
    Jul 2, 2001
    102
    I have a JVC 800 A/V reciever. With stereo sources, such as an older DVD like The Third Man, or a tape recorded in stereo, if I don't turn off the "surround" on the reciever, the sound comes out of the center channel only. Once the surround is turned off, the sound comes out of the two front speakers and the sub.
    Larry.
  13. Ray Kammer
    Ray Kammer Agent
    Feb 6, 2002
    33
    How do you have the A/V signal hooked to your Pro Logic Receiver from your VCR? If you are using an audio output from your TV when playing your VCR and tuning the TV to channel 3 or 4, then the VCR will only output mono sound. In order to get stereo sound (or ProLogic) you must get the audio from the RCA audio jacks on the VCR. Just a thought.
