Do you use a hitch mounted bike rack...
Discussion in 'After Hours Lounge (Off Topic)' started by Kevin_W, Mar 24, 2005.
  1. Kevin_W
    Kevin_W Second Unit
    Jun 22, 2000
    261
    ... that you would recommend? And that can clear the spare tire mounted to the back of a Jeep Wrangler?
    I have a 2" receiver hitch on my Jeep and I need something that will accommodate three bikes.... Two mountain and one that is a young girls 20" bike. Something that tilts is a plus but don't know which harness types are better: the strap or "clamp" type. What are better at protecting the gear/brake cables?
    Budget is flexible but would prefer to remain under $150.
    Thanks!
    Kevin
  2. DougRuss
    DougRuss Stunt Coordinator
    Oct 3, 2001
    195
    Trying to get a good Rack system for under $150.00 will be alittle hard to do?
    Have you tried searching on the Net for the different types out there?
    Here's a link to check out......... Racks
    Also Here
    I have a Jeep Cherokee with a Receiver Mounted Carrier, but I can't for the life of me, remember where I got it ? lol
    Think I paid about $200 for it?
    My Jeep
  3. DonRoeber
    DonRoeber Screenwriter
    Feb 11, 2001
    1,849
    I have a Yakima bike rack for my Explorer, and I'm happy with it. It's a strap style, but only carries two bikes. Fine for my needs. I don't rememeber how much I paid for it, but I got it at my local bike shop. I'd suggest you talk to them.
  4. DaveHo
    DaveHo Supporting Actor
    Dec 11, 2001
    605
    I have this one: Saris Rack
    It's been a number of years since I bought it, but I'm pretty sure it came in under $200. Been very happy with it. Holds the bikes very securely, and tilts. Has a locking bolt to keep it from rattling around in the receiver. I'm not sure if it would clear a tire, but there are extenders you can get for not too much money.
    -Dave
  5. Michael Harris
    Michael Harris Screenwriter
    Jun 4, 2001
    1,344
    When I had a Jeep Cherokee with a rear mounted spare, I had a carrier attached to the spare. It could carry two bikes without any problems. I was easy to mount, use, and remove. Got rid of the Jeep but still have the carrier just in case. I now carry my bikes inside my current vehicle.
  6. Kevin_W
    Kevin_W Second Unit
    Jun 22, 2000
    261
    Thanks for the tips guys.
    I have been looking around but to be honest there are so many different brands and price ranges I don't know what to look for. I didn't know if its one of those things where a cheap $100 model is all you need or the more expensive models secure better.
    Any thoughts on straps versus clamps?
    Kevin
  7. DougRuss
    Oct 3, 2001
    195
    Kevin,
    THe Bike Carrier I had on my other Vehicle ( Suzuki Sidekick) was the "Clamp Style". It worked good and with that type, I was able to lock the Clamping section . Cannot do that with the Strap Type, like I have on my Cherokee,I just run a Cable thru the bikes,and a "I-Bolt" on the hitch portion of the Carrier.
