Do you recommend this for my SVS 20-39 CS+?
Discussion in 'Archived Threads 2001-2004' started by raze, Dec 19, 2002.
  1. raze
    raze Agent
    Dec 14, 1998
    47
    With the release of several bass-intensive dvd's recently,
    I was thinking of using a FMOD crossover from partsexpress to protect my SVS.
    By the way, I have the 20-39 CS+ calibrated at 85dB using Avia.
    Are there any SVS owners using something like this?
    Ray
  2. Jeremy Anderson
    Jeremy Anderson Screenwriter
    Nov 23, 1999
    1,049
    I use the ART-351 EQ with my 20-39CS+, primarily to tame room peaks... but with the added benefit of having a subsonic filter to protect my sub when playing at high levels. Some of these recent DVD's really put your gear to the test, but at least the subsonic filtering helps.
  3. Mark gas
    Mark gas Second Unit
    Mar 23, 2002
    322
    the fmod is only a 6 db xover you might want to try to use 2 or 3 to get a higher slope.
  4. RichardH
    RichardH Supporting Actor
    Nov 28, 2000
    742
