Do tire valve-stem caps keep air in?
Discussion in 'Archived Threads 2001-2004' started by Charles J P, Dec 21, 2001.
  1. Charles J P
    Charles J P Cinematographer
    Aug 19, 2000
    2,049
    2
    Omaha, NE
    CJ Paul
    I have had a slow leak in my front driver side tire for about 4 months, and I just keep fillin it as it gets low. I know I need to get it fixed... last time I filled it it was at 12-15psi :b My question is, that tire as well as two others were low (the others were not as low) two of the low tires, including the one with the known leak have no valve-stem caps. The third tire did have it, but it was a little low too. Barring anything strange, are the valve stem caps needed to keep the air in?
  2. Denward
    Denward Supporting Actor
    Feb 26, 2001
    552
    I'm no expert, but I've always thought stem caps are important to keep your valves clean. Without caps, dirt can get in there and when you go to fill your tire, you may force dirt into the valve and cause it not to close properly.
  3. Andrej Dolenc
    Andrej Dolenc Stunt Coordinator
    Jul 22, 1998
    249
    Correct, the valve stem cap just keeps it clean, it doesn't keep the air in there. The valve itself, with the help of air pressure from the air inside the tire, is what keeps the valve closed, and the air in there.
    Also, changes in temperature will affect tire pressure. As it gets colder, your tire pressure will drop (unless you add air obviously). Though it doesn't sound like that's your problem...
    Andrej
  4. Tom Johnson
    Tom Johnson Stunt Coordinator
    Dec 8, 1998
    158
    The caps are dust caps and do not keep the air in. Have your tires checked. You may have a bad valve, but most likely there is a foreign object lodged in the tire.
  5. James RD
    James RD Supporting Actor
    Aug 4, 2001
    788
    Let's not jump to conclusions. It could be an American object.[​IMG]
  6. Jay H
    Jay H Producer
    Mar 22, 1999
    5,654
    32
    Pittsfield, MA
    Jay
    That's why I use presta valves! [​IMG]
    Oohhh, you're talking about cars... sorry.
    Jay
