Do they make a "Y adaptor" or spliter for internal USB headers?
Discussion in 'Computers' started by Luke_Y, Jul 16, 2003.
  1. Luke_Y
    Luke_Y Second Unit
    Aug 20, 2001
    424
    Do they make a " Y adapter " or splitter for internal USB headers?
    My motherboard has 6 USB ports on the rear panel, and only one internal header that the 2 front panel jacks plug into. I want to put a multi format card reader in one of the floppy drive bays. I was hoping to be able to plug it in inside the case instead of use a standard cable and run it out the back to plug in outside.
    I was thinking you might be able to get a Y adapter similar to the ones for the power connector when you add another optical drive. ?? [​IMG]
  2. JamesHl
    JamesHl Supporting Actor
    May 8, 2003
    813
    You could make one out of a hub, probably. But why not just plug a hub into the front of the case? I guess it'd be kind of ugly, but if you need the ports...
  3. Steve_Ch
    Steve_Ch Supporting Actor
    Oct 14, 2001
    978
    I just saw a USB splitter over at Fry's yesterday, it wasn't "internal" per se, but it's so small that you can probably use it internally. Don't know how much.
