Do these components match up well?
Discussion in 'Archived Threads 2001-2004' started by John Morris, Sep 12, 2001.
  1. John Morris
    John Morris Guest
    As I continue to look for a system to last at least 7 years, I think I've found the best I could ever afford. Let me know what you think about these units and if these components will match up well?
    - Integra Research RDC-7 Preamp/Processor
    - Cinepro 3K6 Gold Amplifier
    - Aerial Acoustics 10-T Speaker System
    I plan on running balanced all the way.
    Is the Cinepro "good enough" for the Aerials?
    Thanks, and Take Care,
  2. John Morris
    John Morris Guest
    Anthony: thanks for the reply!
    I finally decided that in order to buy what I wanted, I needed to sell everything else... hence the all in one system. If the DRC-7 isn't up to snuff for music, which balanced output, 6.1/7.1 pre/pro would you recommend?
    Take Care,
    DFAST, 5C, DVI, HDCP, SafeAudio, Macrovision and Lewinski!!!
