Ryan Leemhuis
- Oct 1, 2002
I will be getting a Kenwood 100 watt powered sub woofer(the one that comes in the HTB-505 HTiB). Will a AR sub cable cause a noticeable improvement in the subs performance or is the normal cable that comes with the box set do a great job as is? The reason I ask is the sub cable is pretty cheap $15 and if it helped out the bass I would buy it. Thanks.
