Do Sony Receivers(lower end) Usually Have Asignable Digital Inputs?
Discussion in 'AV Receivers' started by James Edward, Feb 27, 2004.
  1. James Edward
    James Edward Supporting Actor
    May 1, 2000
    855
    After an extensive day of re-doing someone else's handiwork, I am going back today to finish up
    (spkr levels, spkr size, spkr distance, VE, etc.) adjustments.
    However, no manual was available for the Sony receiver, and all optical and the one coaxial input were clearly marked with DVD, Video1, etc.
    Do you believe that these are hardwired, or should I try and assign them(the cable box only has coax out and it is marked DVD). I know I can just put the inputs in anywhere, but I want them to correspond to the buttons the person is pushing on his remote.
    Thanks for any input(no pun intended).
  2. Nathan Stohler
    Nathan Stohler Second Unit
    Jan 17, 2004
    329
    I believe they are hardwired. Although some of the lower-end Sony receivers allow you to program the name that is displayed on the receiver, the button on the remote will always be tied to the same source.
    To find your user manual, go here:
    Sony IQ Reference Library
