cafink
- Apr 19, 1999
- Carl Fink
If your projector does the best processing of all your components, then your best bet would be to let it do all the processing, wouldn't it? Instead of feeding it the highest resolution you can, which involves using your player's lesser processor for upconversion, thereby degrading the image before it ever gets to your projector, why not feed it the native resolution of the video source? This will result in a less-processed image overall, and an assurance that what processing is done, is done by your best component.
