Richard Paul
- Aug 11, 2002
Since ATSC standards allows for both integer frames per second such as 24fps, 30fps, and 60fps along with NTSC's whacky 29.97fps, which was expanded to allow 23.976fps and 59.94fps, what do most HDTV's display at? Do most CRT displays do 59.94hz while LCD, DLP and Plasmas do 60hz or is it manafacturer dependent? Also with an analog component connection what rates are commonly used, integer or non-integer?
