Do I need shielded wiring???
Discussion in 'Archived Threads 2001-2004' started by Brad Newton, Dec 10, 2002.
  1. Brad Newton
    Brad Newton Second Unit
    Aug 14, 2001
    382
    hook up my speakers. I want to run the wires to the back surronds underneath the floor and then up thru the floor. I am wondering if the electrical wiring, furnace vents, etc will cause any type of interference.
  2. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    I would use wire identified as "in wall" for this type of install. Do not run the wires along with power wires for any distance, nothing else should cause interference. Check your local building codes just in case, eventhough these are not power lines.
  3. RandyKudor
    RandyKudor Stunt Coordinator
    Mar 13, 2002
    67
    Hi,
    Speaker wire labelled as CL-3 is suitable for inwall wiring. It is not so much as a shielding issue as it is for the strength and type of dialetric (insulation) around the strands of wire. Wouldn't want the insulation rubbing against a metal jbox overtime and thus exposing raw wire which could possibly ignite an eletrical fire under the perfect conditions.
    Speaker wire does not need isolation from outside interferences like RF or AC hum.
