Do I need a center spkr.? (1 Viewer)
Bill-Shan
I'm putting together my first home theater system. I have three NHT SB-2's that I was told could be used in the front with one being used as a center speaker. I had planned to buy an NHT SC-1 for the center speaker. My question....as a newbie with "untrained" ears, will I notice a difference between the SB-2 and the SC-1 that is used in the center?
Thanks in advance for any thoughts on this.
ross ish
The sb2 would sound better than the sc1; that is as long as you are not laying the sb2 on its side and are willing to have a center that is upright.
In most cases, the main speaker will always sound better than its specialized counterpart. For pure Aesthetically, manufacturers produce a sonically compromised center channel in the basic mtm configuration. There are inherit problems with this horizontal configuration when used as a center channel.
Kevin C Brown
I 100% agree with Ross. Use identical speakers if you can. If the center is "too high", you could tilt it some so it "faces" the sweet spot a little bit better. Helps with imaging and proper freq response.
Danny Tse
I agree as well with the identical L/C/R speaker setup. One more thing, make sure they are all equal distance from your listening position; if the 3 speakers are on the same horizontal plane, then your center speaker is actually closer to you.
TheThrillisgone
