Do I have a faulty Panny 47WX49?
Discussion in 'Archived Threads 2001-2004' started by Mark_Sk, Aug 27, 2002.
  1. Mark_Sk
    Mark_Sk Auditioning
    Jan 22, 2002
    14
    I have got the Panny 47WX42 and have it hooked up to a Panny RP-62 DVD (previously an RP-56 which was returned as though to be the problem) and when I view DVD's in progressive scan mode I am getting really bad artifacting on most discs, and was especially noticable at the end of American Pie 2 where you get a shot of the sky and the sea (just before credits).
    I have the player hooked up with Acoustic Research component cables, I have also tried with S-video non-prog and I get a slight amount of articafting but not as bad, but the picture is then very dark and red.
    Is this likely to be a TV probelm, or do I have a setting wrong? I have tried to play with the settings on the TV through the normal menu (not the service menu) but none of them make a difference. I have also tried using both sets of component inputs.
    Help would be appreciated before I call in the serivice people.
    I do also have a Malata 520 in transit to me (for all my PAL discs from the UK) and will see if the problem is there with that in Prog Scan mode, but seeing as I had it with both the RP-56 and the RP-62 then I am guessing it is not DVD player related?!?)
  2. Dan Da Silva
    Dan Da Silva Stunt Coordinator
    Feb 14, 2001
    71
    Mark, do you have the Progressive Scan Enabled in the Setup menu, and also you have to have the Progressive Button on the front bottom right hand side of the player pushed in. When Progressive is working there will be a green light on the progressive button I just told you to push. If you have those to things done then you are ready to go, if it still doesn't work then you have a bad player. I have the same player and tv and I screwed this up when I first got it then realized my mistake and now I'm happy, what a great combination.
  3. Mark_Sk
    Mark_Sk Auditioning
    Jan 22, 2002
    14
    I do have the Prog Scan enabled in both places, and I don't think it is a bad player as this is the second player I have had (a RP-56 and this RP-62).
    If I switch off Prog Scan but still use the component I get a stightly better image (i.e. less artifacting) but it is much darker and still not what I wold class as DVD quality.
  4. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    Is your sharpness too high?
    Regards
  5. Mark_Sk
    Mark_Sk Auditioning
    Jan 22, 2002
    14
    Have tried setting sharpness all the way from 0 to max and doesn't help [​IMG]
  6. Rick Pay
    Rick Pay Stunt Coordinator
    Apr 22, 2002
    62
    I'm having the same issue with a brand new RP91 hooked up to my Panny 47wx49. Where do you enable progressive scan in the setup menu of the tv?
  7. Mark_Sk
    Mark_Sk Auditioning
    Jan 22, 2002
    14
    You don't need to enable Prog Scan on the TV, it is automatic
  8. Mark_Sk
    Mark_Sk Auditioning
    Jan 22, 2002
    14
    Anyone? remember it is a WX42 not WX49! (Sorry made a mistake in title and were unable to edit it [​IMG] )
  9. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    How about trying the DVD player on another TV.
    Or trying another DVD player on the TV. May be the DVD player at issue.
    Regards
  10. Mark_Sk
    Mark_Sk Auditioning
    Jan 22, 2002
    14
    This is the second DVD player (as mentioned above) that I have tried, although both Panasonics. I have a Malata 520 being delivered and I will try that when it arrives.
