Do diploes have to be wall-mounted?
Discussion in 'Speakers & Subwoofers' started by Scott Stephens, Apr 15, 2004.
  1. Scott Stephens
    Scott Stephens Stunt Coordinator
    Dec 23, 1999
    130
    I've currently got a 7.1 Paradigm setup, using Mini monitors for my surrounds and Titans as my rear surrounds. I'm considering upgrading to some ADP's for the surrounds, but have a few questions:
    1. Do dipoles have to be wall-mounted for proper effect? (this is not possible in my current setup)
    2. Would it be a bad idea to use dipoles for my surrounds and keep the Titans/Mini monitors (direct) as my rears?
    3. Should I just stick with my current setup?
  2. WayneO
    WayneO Supporting Actor
    Nov 10, 2003
    625
    No, you just would want to try to position them so you sit between and say a foot forward of the two speakers. I really like the dipoles for movies and since you have/I would use, the mini's for the rears, I'd get the dipoles for the sides. But........if you happy with your current setup why change? I demoed dipoles in home before switching from Monitor 7's to dipole ADP 370's for sides/rears for my 5.1 setup and would suggest you do to if you can.
  3. Scott Stephens
    Dec 23, 1999
    130
    Thanks Wayne. I will try to demo a pair before I make the final decision...good advice.
