DIY with old JBL enclosure
Discussion in 'Archived Threads 2001-2004' started by Greg Kolinski, Mar 1, 2003.
  1. Greg Kolinski
    Greg Kolinski Second Unit
    Oct 13, 2002
    331
    I'm REAL new to DIY and kicking around different idea's ,SVS,a custom by Brian B,Parts express ETC.I was wondering if it would be worthwile to use the enclosure from my old JBL PSW1000 sub and use a good driver and amp?Audio Review has a lot of good stuff said about this cheap sub,doesnt get slamed as hard as others in its range.Do you guys think this would be an option,or would I just be horribly degrading a good driver and amp by using an inexpensive mass market enclosure?
    Greg
  2. ross ish
    ross ish Stunt Coordinator
    Nov 18, 2002
    163
    check out rythmik audio. he has a servo system that could plug into any old cabinet. the servo control will account for any t/s parameters. the box size will only determine the output level. if you can enlarge the woofer cutout to take a 12inch driver, you should be set.
    www.rythmikaudio.com
  3. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
  4. Greg Kolinski
    Oct 13, 2002
    331
    any other thoughts on this????
