DIY switching solution?
Discussion in 'AV Receivers' started by Jonathan T, Jul 1, 2003.
  1. Jonathan T
    Jonathan T Second Unit
    Nov 6, 2002
    360
    Anyone know of plans for a DIY switching seperate? I don't need to worry about digital signals or anything better than composite video and analog 2 channel audio. But I need at least 5 inputs. Anyone?
  2. Michael R Price
    Michael R Price Screenwriter
    Jul 22, 2001
    1,591
    Do you mean a preamp? If you build a preamp you'll probably do so with a selector switch of some sort, but you could also just put a switch and a volume control in a box if you don't need a preamp. I think you can use a standard heavy duty rotary (or other) selector switch, or use small switches controlling relays at the output.
  3. Jonathan T
    Nov 6, 2002
    360
    I don't need any volume control, it's only for video games. I'd have to relay 1 video and 2 audio signals. Should be easy.
  4. Michael R Price
    Jul 22, 2001
    1,591
    I sense a "ghetto" switch-and-wires-hanging-in-free-air sort of thing coming along. Well, that's what I would do. Oh wait, I already did it. [​IMG]
    [​IMG]
  5. Jonathan T
    Nov 6, 2002
    360
    [​IMG] [​IMG] [​IMG] That's what I'm talkin about. But I need 5 inputs. I can probably just make a 5 input one from your picture.
    Edit: or maybe not. I can't really see what wires go where. You got a schematic?
  6. Michael R Price
    Jul 22, 2001
    1,591
    This one is complicated because I used two 2-position Radio Shack switches to switch between 3 sources (computer, CDP and radio). If I were you I'd find a nice 6-position rotary switch like Digikey part CKC7004-ND... you'd need a pair of that kind of switch or you could use a more expensive 2-deck model to do both channels at once. Wire the signal lines from the sources to the different positions on the switch and wire the output line to the switch's "pole." You can connect all the signal grounds together, at least that's what I did.
  7. Mark Hedges
    Mark Hedges Second Unit
    Mar 21, 2003
    442
    I bought a 5 input a/v switcher at EB for $20. Switches composite and S video, and even will convert to RF if you want it too. It included some cheap cables and the transformer to power the RF converter.
    Not that I have anything against DIY but I think $20 is a pretty fair price for what I got.
    Mark
  8. Jonathan T
    Nov 6, 2002
    360
    Mark, that sounds good. Thanks.
