DIY SVHS Cables?
Discussion in 'Archived Threads 2001-2004' started by BobMcN, Feb 11, 2003.
  1. BobMcN
    BobMcN Extra
    Jan 27, 2003
    20
    I just ordered some Parts Express gold S-Video connectors (091-1216)but I have a question about which wire to use. Belden has 2 wires which look promising:
    1808A (which is 2 shielded (90% coverage), 30 ga tinned copper connectors within 1 outer jacket)
    7700A (which is 2 shielded (98% coverage copper braid), 30 ga tinned copper connectors side by side, plenum/teflon insulation)
    Now I know about the magical properties of teflon. The 7700A also has better shielding, but the side by side geometry may pose a slight problem with the S-Video connector.
    Any thoughts?
    Bob
  2. Seth_L
    Seth_L Screenwriter
    Apr 5, 2002
    1,553
    Not to belittle your idea, buy why are you making DIY s-video cables? I can understand speaker cables, and RCA, BNC, component, and composite. S-video isn't exactly a crimp on operation.
    I've heard that s-video cables can be touchy to make. Myself, I just bought some Dayton Audio s-video cables from Parts Express. I plan on making my own RCA cables for audio, but I decided to just buy some premade s-video cable because it didn't seem worth the hassle.
    Seth
  3. BobMcN
    BobMcN Extra
    Jan 27, 2003
    20
    I've turned into a self-confessed soldier junkie. I can get a 5' sample length of either of these wires for free. So the cost is only about $5 for the connectors and my time/patience to soldier the tiny, tiny wires - vs about $35 for store bought of the same/less quality.
    Thanks for your concern.
    Bob
  4. Ted Drain
    Ted Drain Agent
    Oct 3, 2002
    46
    For short runs, the 1808A works fine. For longer runs, I suggest buying/building a break-out cable.
    Build a short (6") cable from 1808A with an SVHS connector on one end. On the other end, split the coax cables and attach male BNC connectors. Then make your run with 2 cables of high grade video cable with BNC's on the ends.
  5. Ted Kim
    Ted Kim Stunt Coordinator
    Apr 11, 2002
    214
    I've read the 7700a is better. Furthermore, shielding is very important in video cables. You can add a telescoping shield for even better results.
    BTW, I own some generic SVHS cables that have the same zip configuration as the 7700a.
