DIY subs
Discussion in 'Archived Threads 2001-2004' started by Shawn.G, Nov 4, 2002.
  1. Shawn.G
    Shawn.G Second Unit
    Oct 28, 2002
    265
    i have been told by many of you to maybe go with diy subwoofers. i have to admit i barely know anything about them. Any information is greatly needed. Thanks
  2. Jeremy Stockwell
    Jeremy Stockwell Supporting Actor
    Aug 9, 2001
    608
    Shawn, there is a wealth of information over at the DIY section here on HTF.
    Happy reading!
    JKS
  3. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    It might be easier if you asked in the DIY/advanced forum.
  4. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    Let me move this thread there. I sure learned a lot from that section.
  5. Mike Sloan
    Mike Sloan Second Unit
    May 18, 2002
    456
    www.stryke.com/default.htm good place to get started. Look at the 15.2 enclosure with the HE15 driver!
  6. Mike Sloan
    May 18, 2002
    456
  7. Jeremy Stockwell
    Aug 9, 2001
    608
    Shawn,
    Do you have a budget in mind?
    Do you have a driver in mind (Stryke (linked above), Tempest, Tumult)? Do you have a driver size in mind (10", 12", 15")?
    Do you have any size limitations with regard to the enclosure due to either location or WAF (Wife Approval Factor)?
    Any problems aesthetically with Sonotube (cylindrical enclosure)?
    What size room will the sub go in?
    What equipment do you currently have? What's your current HT setup. What sub are you using now, if any?
    Do you listen to mostly Music or HT? 50/50?
    Provide some additional information and people will probably be more willing to offer suggestions. You can go hundreds of different directions in DIY. Some additional information from you will help narrow the path.
    There are plenty of helpful and knowledgeable members here. "Help us . . . Help you." [​IMG]
    JKS
    JKS
  8. Greg_R
    Greg_R Screenwriter
    Apr 9, 2000
    1,996
    Portland, OR
    Greg
    Also, do you have access to any wood working tools? (specifically a saw and router)
