DIY sub with Car Audio driver? I know its been asked before.
Discussion in 'Home Theater Projects' started by Jesse Sharrow, Mar 15, 2004.
  1. Jesse Sharrow
    Jesse Sharrow Supporting Actor
    Jul 11, 2003
    745
    I have a 12" Infinity Perfect DVC sitting under my bed. It is an awsome driver, but its meant for car audio. Could I make a decent enclosure for it for home, till I can afford my SVS PC-Ultra? Get a decent plate amp. Nothing too powerful. I dont mind doing the work, just is it even worth it.
    http://manuals.harman.com/INF/CAR/Bo...s/P12.1d_f.pdf
    Thats the specs for it. Now it has sound wave charts, in and out of car. It doesnt look too bad out of car. Any suggestions? Becuase I could proably build a decent box or maybe even cylinder style sono tube for it. Is it worth it.
    Maybe throw this amp onto it...
    http://www.partsexpress.com/pe/showd...number=300-808
  2. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    It's a good driver.
    Several people have used it in this box for HT/music.
    4.24 cu ft box/tube, one port 4" dia 14.9" long, Fb 21.03Hz, F3 20.83Hz
    Have fun,
    Thomas
  3. Jesse Sharrow
    Jul 11, 2003
    745
    Thats a huge box but I dont care. Now do you guys think this is worth it? Im thinking of blowing my sub and trading it for a single 4ohm... I have a 5yr on it. Now its going to be the DVQ so I may need different specs for it.
    http://manuals.harman.com/INF/CAR/Ow...2012-2-02).pdf
    I was going to use this amp. http://www.partsexpress.com/pe/showd...number=300-793 Now do you think this is a worthwhile endeavor? Will it give me good quality? Close to SVS quality? If not can what is a good home driver to use? Also what sort of wood should I make this out of?
  4. Dennis Gardner
    Dennis Gardner Stunt Coordinator
    Dec 12, 2002
    206
    Grow up!
    Do the right thing.
    Build yourself a box.
    Don't rip off HK.
    In customer service as you are, don't you hate jerks?
    Don't be one.
    Enjoy your DIY sub, it may sound awesome!
  5. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    [​IMG]
  6. Wayne Ernst
    Wayne Ernst Cinematographer
    Feb 24, 2002
    2,588
    Jesse,
    Use some of the free software out there to "model" a nice box that you could build. The amp you are looking at is a good amp. If you feel that it might be a while before you pull the plug on your SVS purchase, you might consider spending a bit more $$ and get a pro audio amp. This could provide you with more power, two channels of amplified power and have more flexibility for future sub projects - if that's your interest.
    Finally, using a car sub for home use can be an O.K. thing. Keep in mind that all car subs will not be perfect. However, those with parameters that match more closely to home use are.
    With that being said, I'm working on a few "test" enclosures where I'm using a 10" car driver and shortly a 12" car driver. Also, keep in mind that the Adire Audio 12" Shiva driver has a very dedicated following for home theater users. But, there are plenty of car audio enthusiasts running this driver in the trunks of their cars, too. It's a "two-way" street - no pun intended. [​IMG]
    Enjoy ! [​IMG]
  7. Jesse Sharrow
    Jul 11, 2003
    745
    Dennis.... um ok?!?!?!?
    Wayne: I didnt think of that. I could always get a seperete pro audio amp, that way I could get an SS later on. [​IMG] Maybe thats the way I will do it. Thanks for the input.
    Also where would I find a box building program. Because right now I am going to go off of the specs that Thomas gave me.
  8. ThomasW
    Nov 6, 1999
    2,282
    12" Infinity Perfect is a good driver for home use. The cab specs I posted are designed for optimal performance.
  9. Jesse Sharrow
    Jul 11, 2003
    745
    Well I acctually ended up getting store credit for the sub, so I bought my Boston Center Channel instead. This way I am just going to wait till I can afford the SVS. Thanks again guys.
  10. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    You could by an Adire Tempest and a 250W plate amp for less than $300 and build a sub that will match an SVS Ultra for performance. Trade off being the enclosure will be 2-3 times as big.
  11. Jesse Sharrow
    Jul 11, 2003
    745
    Seriously? Have you heard an Ultra to compare that too? Becuase if that is true maybe it worth a shot.
  12. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    Yes seriously. I haven't heard an Ultra personally, but technically from a raw output stand point they should be very close. From a sonic signature stand point I have no idea.
    Although you have a lot of control with the Tempest on how it will sound by the alignment you choose.
  13. Wayne Ernst
    Feb 24, 2002
    2,588
    The tools to get are:
    - LspCAD
    - WinISD
  14. Wayne Ernst
    Feb 24, 2002
    2,588
    Thomas,
    Thanks for the recommendation on a driver. It's always good to know of such drivers to have access to, if needed.
    Another such driver is the JBL GT120 - which I learned about from another forum member here, too. The specs are a bit close to that of the Shiva. The GT120 can be picked up for $45 ~ plus shipping from some vendors @ Yahoo! Shopping.
  15. Jesse Sharrow
    Jul 11, 2003
    745
    Well sonically accurate is what I want. I dont care too much about output. I want it very accurate.
  16. TanT
    TanT Stunt Coordinator
    Dec 17, 2002
    135
    Jesse, Dustin is right about the Tempest vs the SVS Ultra. I used to have a Tempest in a Mid Q sealed box and a SVS Ultra.
    I had them both hookup to each channel of the Samson S1000.
    The frequency resp. charts for both are almost identical. The Tempest actually hit a hair lower than the Ultra.
    At low to mid volumes (typical listening) the Tempest will play louder than the Ultra. The Ultra will catch up with the Tempest at extremely loud volume. I didn't really push them into clipping territory but had a feeling that the Ultra has more gas left in the tank than the Tempest.
    I showed both Subs to my friend and eventually he bought the Tempest from me [​IMG]
    If you decide to go with the Tempest my advice is to find something thicker than 3/4 inch for the sealed enclosure. This monster will vibrate the box quite a bit.
  17. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    *Shakes Head* [​IMG]
    I guess everyone missed that part... Gee I want something
    better than what I have now.. I have a warranty on it..
    Maybe I should intentionally break it so the manufacturer
    replaces it....
    Aside from mismanagement no wonder companies go bankrupt..
    /Rant off
