DIY sub plan (WinISD) - please review:
Discussion in 'Home Theater Projects' started by Kenneth Harden, May 25, 2005.
  1. Kenneth Harden
    Kenneth Harden Screenwriter
    May 13, 2002
    1,365
    This woofer:
    http://www.partsexpress.com/pe/showd...number=295-560
    This amp:
    http://www.partsexpress.com/pe/showd...number=300-806
    This port:
    http://www.partsexpress.com/pe/showd...number=268-352
    ~7 cu. ft. box. tuned to 20 Hz.
    Gets me at a -3 point of 20 Hz. and at 1 meter, max SPL's around 110-115 dB.
    Seems for under $500, this would be hard to beat.
    What am I missing?
    Thanks!
    ANOTHER QUESTION:
    If I made a 15 cu. ft. box (HUGE!!!!!), the program says I would have bass well below 20 Hz. (like 15 Hz.) before my -3 point - would it really, or would the woofer not be able to do it (in a small bedroom)?
  2. BlakeN
    BlakeN Stunt Coordinator
    Sep 15, 2002
    185
    I am at work so I can't run the numbers but I would look at your linear excursion. I would guess that you will be going beyond 10mm and bottoming out that driver.
    I would Highly suggest you look at this sub its $20 more but well worth it.
    Atlas 15"
    Here is the graph of what it will do in a ported enclosure.
    http://www.ascendantaudio.com/archiv...0Q%20graph.htm
    Its discontinued though so order quick if you want one.
    Your also going to need more then one port 2 at the least 3 would be better.
  3. Jack Keck
    Jack Keck Second Unit
    Nov 23, 2001
    269
    I used all the same stuff in a box that's between 5.5 & 6 cubic feet. I left the port full length. I chose the amp because it was on sale. The plan was for the 240 watt amp. I'm glad I bought what I did because I used the parametric equalizer to boost the lowest frequencies. I hope you enjoy your sub as much as I do mine.
    I hope you have a RAdion Shack meter and some test tones. They'll come in real handy. Be gentle with the gain control.
  4. Kenneth Harden
    May 13, 2002
    1,365
    I am just playing - problem is, I have no woodworking tools [​IMG]
    I have a router, and would gladly buy a Jasper Jig, but then I would have to buy a table saw, and it would get a bit spendy.
    Someday...
  5. Mark--M
    Mark--M Stunt Coordinator
    Apr 20, 2005
    100
    According to unibox, the driver will be reaching 15mm excursion at around 30 hz. Even 250w will put it past the 10mm excursion limit.
    A 250W amp and a 7cu.ft. box tuned to 22Hz would probably work ok.
  6. Jack Keck
    Nov 23, 2001
    269
    Quoth Kenneth:
    "I am just playing - problem is, I have no woodworking tools
    I have a router, and would gladly buy a Jasper Jig, but then I would have to buy a table saw, and it would get a bit spendy."
    I paid $12.50 for my table saw.[​IMG] OK, I had the lumberyard cut the panels for me. I used a jigsaw for the speaker and port cut-outs, and a circular saw for the amp opening. I also had to trim the sides, but that's another story altogether.:b
    PE recommends a 5.5 cubic foot box. I messed with WinISD and this seemed the most feasable to me. I was able to cut all six sides and braces from one 4' X 8' piece of mdf. This was important because the amp. although I got it for $197.00 before Xmas, wa sa large cost overrun. Of course, if you figure that I would have needed a BFD or similar equalizer, then it saved me a few bucks.[​IMG]
  7. Wes
    Wes Screenwriter
    Sep 30, 1997
    1,190
    Utah USA
    Wes Peterson
    Here is my Quatro box, well boxes!http://prosteering.8k.com/custom4.html
    I first tried a longer port but I hated the sound. I love a good solid punch for music and still have plenty low end for HT which I achieved with these babies!
    I am running one Rythmic 350w amp running at 8ohm so about 250ish watts. I never bottom out and can run the full 350w with no problems.
    Wes
