DIY sub crossover, 80hz/at least 24db/octave
Discussion in 'Archived Threads 2001-2004' started by RichardMA, Apr 17, 2002.
  1. RichardMA
    RichardMA Second Unit
    Apr 16, 2002
    446
    Has anyone ever seen an active crossover design that
    can do the above? I figure it might make more
    sense than a hulking inductor/cap bank.
  2. Peter Johnson
    Peter Johnson Stunt Coordinator
    Nov 12, 2000
    136
    [​IMG]
    OP amps are dual-TL072 type opamps (ie you can use BB 2604/2134's etc).
    For an 80Hz crossover, replace the resistors with 42-43k ohm 1% metal film resistors.
    And its power supply..
    [​IMG]
    See projects 5 and 9 at www.sound.au.com for more info.
    PCB's can be ordered.
  3. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    Marchand has designs that can do 24 or 48db/octave at any frequency you want. They have assembled units, EZ-kits, complete parts kits, or raw PCBs
    http://www.marchandelec.com
  4. RichardMA
    Apr 16, 2002
    446
    Thanks for your help!
