DIY Sub advice: one or two?
Discussion in 'Archived Threads 2001-2004' started by TomHa, Apr 2, 2002.
  1. TomHa
    TomHa Auditioning
    Apr 1, 2002
    2
    I am considering taking the DIY plunge and am considering two options:
    1) Two EBS Shivas to be used as stands for my mains.
    2) Single EBS Tempest placed in a corner.
    I have an oddly shaped 4300 ft^3 room with vaulted cielings that is open to the kitchen, and I am somewhat concerned about the two sub option complicating my room response. There seem to be many conflicting opinions regarding apropriate placement of multiple subs. I would apreciate any words of wisdom regarding the use of dual subs as stands. I realize that the Tempest option would be less expensive.
    Thanks.
  2. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    That's a big room. Can you accommodate a single tube big enough to use 2 Tempests?
  3. Andy Anderson
    Andy Anderson Second Unit
    Dec 11, 2001
    317
    TomHa-
    Eric Jones uses 2 subs as stands. one's a Shiva, the other's an older SVS driver. Check it out:
    http://www.jones4.com/ss
    He might be able to give you some pointers, although his room is not as large as yours. He's a freaking woodworking wizard.
    Andy
